Gutting your pre cats
Old Jul 21, 2011 | 07:08 PM
  #41
036mtmax's Avatar
That's what nmexMAX, too, did with his header set-up. I was thinking of leaving the sensors in the exhaust, so it wouldn't be so obvious when doing a visual inspection. Although in NY, I'm pretty sure the visual inspection is simply to confirm existence of the main cat.
Manny sold me an old, unused SIM from years ago. It's pretty backyard-electronics, but if it works it works. 036mtmax, where'd you get your sim?
I havn't got one yet because i heard 02sim went out of business so im waiting to hear someone chime in if they know where i can get a descent one..
Old Jul 21, 2011 | 07:11 PM
  #42
036mtmax's Avatar
oh Eirik,lol
Originally Posted by Eirik
Not to beat a dead horse, but after reading that, who honestly still believes that their pre-cats disintegrate backwards into their engine and cause the rings to fail and the engine to die!?
Old Jul 21, 2011 | 08:18 PM
  #43
OnOiShNo0dl3Z's Avatar
Just a question since I'm considering gutting my cats. Why not just use spark plug non foulers? Much easier to get and cheaper.
Any reason why you aren't considering or mentioning them?
Old Jul 21, 2011 | 08:30 PM
  #44
036mtmax's Avatar
i was going to try them to see if they work if i can't find sims
Old Jul 21, 2011 | 09:41 PM
  #45
jeff5347's Avatar
i havent posted on the site for a few months but i did this mod last year before winter. TO get rid of the SES light all you need it 4 spark plug antifoulers. 2 short and 2 long. Drill out the 2 long ones so thr o2 sensor will fit. Put it all together and it the 2 sec o2s will read less than the primaries therefore no light. I get a light once in a while say if i dont drive the car for a week but i just do the ecu relearn and good to go. Nice to know is all i need is a better exhaust than stock and i may be at the 240 mark. Have all those mods as well minus the larger exhaust but have the SSIM.
Old Jul 21, 2011 | 09:43 PM
  #46
TallTom's Avatar
Werd. Like two of these: http://cgi.ebay.com/ebaymotors/O2-Ox...Q5fCarQ5fParts
Old Jul 21, 2011 | 09:50 PM
  #47
036mtmax's Avatar
nice jeff thanks for the info ill give it a shot first..
Old Jul 27, 2011 | 06:22 AM
  #48
Rochester's Avatar
Mechanic has the car today. Gutting both pre-cats and installing the O2 sim. Sitting here at the office, hoping for good news before the day is out.
Good news would mean:
1. The low-end mystery rattle will be gone.
2. The O2 Sim install was done accurately, with no CEL.
3. The original-equipment main cat is still A-OK.
4. (optional) Improved power with the exhaust efficiency.
Old Jul 27, 2011 | 07:09 AM
  #49
Xpcgamer's Avatar
Thats sweet. Keep us posted. I would love to hear how the new found PAWAA smoked the tires on the highway doing 80!
Old Jul 27, 2011 | 08:12 AM
  #50
TallTom's Avatar
Nice!
Old Jul 27, 2011 | 09:08 AM
  #51
Eirik's Avatar
I'd definitely use the O2 extensions/whatever you want to call them, before buying a sim. They're a widely-known "secret" that hasn't penetrated into this particular forum for some reason. The 4th gen guys are all about 'em--my '97 owning friend was able to defeat the big-cat-not-working-right CEL, even.
I wanted to use the horse thing, but didn't like the repost sign he was holding, so I refrained.
@the guy who said "BUT EIRIK FRONT PRECAT SOMETHING SOMETHING": It's not KRRZ's theory, he just defends it because he tore down that one engine that one time and saw some of the rings were bad, but not all of them, and concluded that that can only be from the disintegrating pre-cat theory, and not that just some of the rings were bad/installed wrong when the car was assembled.
"Always" is a strong word. My '05 6MT has shown no signs of burning oil in the 2500 miles I've put on it (95->97.5K miles). Though I didn't own it then, I estimate that my '02 was burning about 1 qt/2500 miles around then, worsening to 1qt/800 miles after 120K miles before levelling out to 1qt/~1400 miles when I destroyed it at 133K miles.
Old Jul 27, 2011 | 09:39 AM
  #52
Prophecy99's Avatar
your mechanic seems really cool, and he must love you by the way u are with your car.
Old Jul 27, 2011 | 10:10 AM
  #53
Rochester's Avatar
IDK about that. He mocks me relentlessly. I think he's trying to see how far he can go before I cry out with non-mechanic like shame.
Still waiting. Apprehensive to hear, "Snapped these bolts", "Main cat is toast", or the worse... "The mystery rattle is still there."
But then, I don't want to jinx this thing.
Old Jul 27, 2011 | 11:02 AM
  #54
Nismod00d's Avatar
your low end mystery rattle isn't the timing chain rattle right?
Old Jul 27, 2011 | 11:34 AM
  #55
Rochester's Avatar
No. If it were, then it would have been obvious applying the listening tool to the timing chain cover.
Just got off the phone with my mechanic... the rear pre-cat was successfully gutted while on the car, (and on the lift). It took about an hour. The front pre-cat is next, and that obviously needs to be removed.
Like (most) everyone here was saying: the rear is easy to access, but a PITA to gut. Whereas the front is a PITA to access, but easy to gut.
More later.
Old Jul 27, 2011 | 12:13 PM
  #56
TallTom's Avatar
Like everyone here was saying: the rear is easy to access, but a PITA to gut. Whereas the front is a PITA to access, but easy to gut.
More later.
Sexy time!
Old Jul 27, 2011 | 12:55 PM
  #57
Froggmann's Avatar
Old Jul 27, 2011 | 12:56 PM
  #58
Rochester's Avatar
The front pre-cat gutted effortlessly, although he had to laser-torch a few inches off the manifold heat-shield in order to access the bolts without dropping the heat shield... which he preferred over the alternative, which was potentially trashing the entire heat-shield.
He said there was a metal ring within the front pre-cat which looked like it should be pressed into the pre-cat housing, and yet just fell out as things were unbolted. The suspicion is that my low-end rattle was this loose ring thing... because the visual inspection of all the cats led him to think they were all fine.
While it kind of sucks that this noise could have been addressed by simply removing the ring , I'm going to end up with gutted pre-cats at the end of the day. And according to a number of people here, that's a thumbs-up situation.
Either way, I'm not picking the car up until tomorrow.
Hi, Froggy!
Old Jul 27, 2011 | 12:59 PM
  #59
nelledge's Avatar
"I'm just sayin'..."
The metal ring is not pressed in. I seriously doubt that was your noise. Let's cross our fingers and hope it was something in the rear cat that he couldn't see. I'm still betting on the heat shield a tiny bit loose due to corrosion at the fastener.
Old Jul 27, 2011 | 01:00 PM
  #60
Rochester's Avatar
Oh. Well, damn it, then.
Old Jul 27, 2011 | 01:04 PM
  #61
nelledge's Avatar
Like you said, there are unintended advantages. I bet you'll be surprised at the difference in power. It's not headers, but it is definitely different. You'll see.
Old Jul 27, 2011 | 01:32 PM
  #62
TallTom's Avatar
Hi, Froggy!
How much is your mechanic charging to gut the cats?
Old Jul 27, 2011 | 01:47 PM
  #63
Rochester's Avatar
Do you know what it's there for? I'm not at the shop, so I'm kind of fuzzy about what he's describing over the phone.
Haven't been billed yet. Besides, we never talk about cost, and he's never charged me anything I wasn't prepared for. Been going to him for years. He's a rare thing... an honest mechanic.
Old Jul 27, 2011 | 02:55 PM
  #64
nelledge's Avatar
Do you know what it's there for? I'm not at the shop, so I'm kind of fuzzy about what he's describing over the phone...
I believe it's to contain the catalytic material within the cat. It appears the body of the precat has a cylindrical hollow space in which the preformed material is dropped in. The ring is then placed on the shelf at the top. In other words, it's designed to facilitate the ease of manufacturing.
Old Jul 27, 2011 | 04:06 PM
  #65
Xpcgamer's Avatar
Oh well I can't get the page up, but if your talking about the forward Pre cat I see no o ring on the schematics. Page 10 of the EM section of the Service Manuel. The is a metal ring that goes after the pre cat but nothing where it connects to the manifold. I forgot where you said the ring was at.
Old Jul 27, 2011 | 04:16 PM
  #66
nelledge's Avatar
It won't be in the FSM schematic. It's not a separate part. It comes with the cat. Check out the image on this page. You can see the ring at the inlet.
Old Jul 27, 2011 | 04:27 PM
  #67
Xpcgamer's Avatar
OIC0-It looks like a big flat washer.
Old Jul 27, 2011 | 04:38 PM
  #68
036mtmax's Avatar
Glad to hear you got it done Rochester..I think that it probably was the cat making noise because mine failed around 65/68k.In for feed back and opinions.
Old Jul 27, 2011 | 05:21 PM
  #69
gsxr-rider137's Avatar
so removing the pre cats is not going to affect emmisions in any way?
Old Jul 27, 2011 | 06:23 PM
  #70
spock's Avatar
Of course it is. That's why O2 sims will be introduced.
Old Jul 27, 2011 | 06:41 PM
  #71
nelledge's Avatar
The precats do the preliminary conversion of exhaust gases immediately (albeit with a smaller conversion efficiency) since the main cat must reach operating temperature to work at optimum efficiency. Taking out the precats yields 'dirtier' exhaust gases for the first few minutes of engine operation.
Old Jul 27, 2011 | 07:05 PM
  #72
TunerMaxima3000's Avatar
To clarify, I don't think 'rattle' is the correct word John, not from what I heard. It's a whistle or whine type noise, like an IPS bearing might make.
I still suspect that there was one area of the cat that had created a 'flute' which caused a whistle noise to resonate through the exhaust, but only at a certain resonace (RPM/Load)
Can't wait to hear the results
Old Jul 27, 2011 | 08:25 PM
  #73
036mtmax's Avatar
Nope mine was a distinct heat shield sounding rattle and when we took the cat down the bulk of the mesh inside the cat was shifting around inside the cat which was causing the noise.
Old Jul 28, 2011 | 04:30 AM
  #74
Rochester's Avatar
I think you're right about that. "Rattle" is the first, best descriptive term that comes to mind, is all. Another analogy I've been using lately is the little ball (called a "pea") inside a police whistle.
For those who are reading this... TunerMaxima3000 tried to analyze this noise last week, so he's exactly familiar with what I've been experiencing.
Old Jul 28, 2011 | 04:44 AM
  #75
Xpcgamer's Avatar
Did you get your car yet? Problem fixed?
Old Jul 28, 2011 | 04:58 AM
  #76
Rochester's Avatar
When we spoke towards the end of the day yesterday, he had just bolted everything back together, and was about to start on the O2 Sim. I told him not to sweat it, and leave it for the next day. No sense in forcing a deadline when I'm in no rush to get the car back. We're a 2-car household, and I mostly work from home.
I have to admit, all this talk about power gains has me a little psyched. Naturally, headers are the optimal approach, but maybe gutted pre-cats mated to a Cattman y-pipe will be a pretty close second.
Old Jul 28, 2011 | 05:23 AM
  #77
Xpcgamer's Avatar
Cool. I was looking at getting a Y Pipe and mating it to gutted pre cats myself. Hopefully you do get some gains. Maybe you could compare with somebody running OBX headers? OP, How is your car running?
Old Jul 28, 2011 | 06:54 AM
  #78
Rochester's Avatar
Unless you already have the y-pipe (like I did), or can get a quality aftermarket y-pipe on the cheap... I wouldn't recommend this approach. OBX headers would be a far more cost effective and productive mod.
Not going to happen. I don't care about dyno numbers, and there aren't any other 5.5 gen Org members in my area. However, if there were another modded 5.5 gen around here, I would love to compare this and a number of other things. Thank God for the Org... sometimes I feel like I live on an island.
Old Jul 28, 2011 | 07:01 AM
  #79
Xpcgamer's Avatar
I commend you BTW for being able to work from home. I CANNOT. I could if I wanted too but the kids see me at home and think "Yay! Party with daddy today!" and I get nothing done!
Old Jul 28, 2011 | 07:04 AM
  #80
dnice02's Avatar
Who all still makes y pipes for are cars? That sounds like a good idea to mate an aftermarket y pipe to gutted cats.
