evap purge valve code...replaced valve code still pops up?
Old Aug 6, 2011 | 07:43 AM
maxima dude's Avatar
so im in a lil pickle i get a p0444 evap purge valve stuck open and i get a brand new 1 from nissan and the code still came up
any ideas on how to get rid of it ? i guess ill look for cracked hoses or **** but any tip wuld help
Old Aug 6, 2011 | 09:35 AM
tothemax2003's Avatar
it has to be a brken hose like a pin hole in the hose
Old Aug 6, 2011 | 12:57 PM
V.S_Maxima's Avatar
Check your whole fuel system for leaks. Do you smell gas anywhere? Its usually a Gas cap issue. Make sure the ring in your gas cap is not cracked. Otherwise you are getting air in your fuel system somehow. Maybe you shook loose a fuel line take a look at everything from the pump to the tank. My buddy had a cracked line near the tank when he had this code.GL
Old Aug 6, 2011 | 01:03 PM
knight_yyz's Avatar
Toolie
there are two valves, one on the canister and another close to the canister about a foot away
Old Aug 6, 2011 | 01:52 PM
DennisMik's Avatar
You have the valves mixed up. You are referring to the EVAP Canister Control valve which is attached to the canister and the EVAP Control System Pressure sensor or the Vacuum Cut Valve Bypass valve.
The EVAP Canister Purge Volume Control Solenoid valve is under the hood, bolted to the intake manifold.
Old Aug 7, 2011 | 12:34 PM
Chris Gregg's Avatar
Get Off My Lawn
+1 However.......my bad gas cap threw a 455 code, never got a 444 code.
shilov
Feb 19, 2024 09:40 PM
msellas
Sep 23, 2015 09:16 PM
homeofbacon
Sep 23, 2015 07:17 PM
Steven Orozco
Sep 12, 2015 10:41 PM
dcam0326
Sep 7, 2015 07:26 AM
