Hmm thinking about cutting the cats this week..
#41
Just a quick question to go with this thread. I know that one of the side effects of gutting the cats is a possible CEL. Will simming the O2 sensors keep this from happening? Or does this job deal with the primary O2 sensor that sends information about air/fuel ratios back to the ECU which can't be simmed?
#42
#43
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
#44
Yea the bolt that "stripped" it actually just started to spin on itself, it actually did no damage to the threads on the manifold so i found another bolt with the same dimensions and put it in there...I finally got the rear heat shield off and i just got off the 2 (top side) nuts and broke loose 1 of the 2 underneath nuts. once this last 1 comes out the manifold will be all mine. My airchisel arrived about an hour ago so im just about ready to get it done. Itll all be down to reinstalling, going out and buying either the o2 sims or the sparkplug antifoulers... all in all i should be up and running by the end of the weekend. Thats if the hurricane doesnt blow us away..
#45
You may have missed when he stated he stripped a couple studs. It is magnitudes easier to address a frozen stud with the assy off the car. I actually did this as well because of a sheared stud(impatience). The front manifold comes off in no time. Try to drill out a stud on the small radius bend side of the cat while it's on the car? I think not. ![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
I did miss the part about the stud being stripped
![Embarrassment](https://maxima.org/forums/images/smilies/redface.gif)
#46
rear cat is off the cari started gutting it but that thing is a beotch compared to the front 1... so much harder and more dense.it took me about 15 minutes to poke through the other side but i decided to call it quits for the night i dont htink the neighbors like my air compressor and chisel going full blast at midnight lol so ill start back up on it tomorrow.. Im just wondering now if i should just go ahead and bolt it all up and run it or take the time out to address the main cat also....i might just get it all together and take it to a muffler shop to cut it out and weld in a straight pipe but i dunno what do yall think?
o and 1 more thing about these simulators, can i just go right to autozone or pepboys and ask for 4 of these o2 sims??
#47
The electrical sims are kinda hard to find as they are "illegal". That being said there are a few sites that still sell them just search...
If your looking for the Anti Foulers for the secondaries those can be bought at any auto parts stores.
EDIT:
Not sure if this will work for the max or if any one on the Org has bought one and used one successfully. They are meant for a 3000gt/stealth so...
http://www.3sx.com/store/comersus_viewItemBundle.asp?idProduct=769
EDIT:
#48
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
Go search the Org on "plug fouler" and give that a shot. Less expensive than a Sim, and far easier to purchase.
#49
Rochester, did you go with the sims or anti-fowlers? Is it just the two O2's I have to fool if I only gut the pre's? I'm still waiting for my y pipe so I'm just trying to get things together before hand
#50
Buddy, this is where you and I get into a sissy fight about who's mechanic is better, while the rest of the Org mocks us both for not turning our own wrenches (like the OP... brave, brave Sir Robin). ![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
Yikes! You didn't research Sims before starting this project?
Rochester im not trying to fight about anything and it makes no difference to me who's mechanic is better as long as mine fixes my car.Im just stating that it is not possible to gut the rear bank pre-cat while it's still bolted to the manifold.If you watched your mechanic do it you would understand what i mean.
#51
Go to autozone in the HELP isle and pick up two 18mm anti-foulers(the longer of the two) theres short and long 18mm I been like 700 miles with no cel
#52
![Rotz](https://maxima.org/forums/images/smilies/rotz.gif)
But seriously, you have to stop saying it's not possible to gut the rear pre-cat while still on the car, when people have done exactly that. You're confusing teh noobs.
#53
Nah i just have i hard time reading people i guess bud
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
#54
From what ive seen being under the car while the rear bank was still on is that it looks like its enough room to get the airchisel or w/e up up in the cat to gut it but the material is sooo hard that you would be better off taking out the 4 bolts dropping the cat and putting it up on a bench vise to gut...i have mine ontop of a trash can so the material will just fall in there but to each his own i just know i wouldnt want to be underneath that cat when that shyt is falling down in your face...It could be done tho i believe..
Anyways so all i need is 2 18mm anti foulers from autozone to get rid of the cel?? which 2 do i put them in? Im counting 5 sensors total...pretty confused on which 1's will need them
#55
The secondaries provide measurements that compare against measurements from the primaries. You need to spoof the signal coming from the secondary O2 sensors.
#56
You just need a o2 dual simulator like this. Don't know if they are still selling them, but just an example.
http://www.o2simulator.com/index.php...products_id=10
#57
![Cool](https://maxima.org/forums/images/smilies/cool.gif)
I chose to not go this route because it would be extremely difficult without a lift and there are possible consequences for debris to become a potential problem. However, it is physically possible. If you would like, I would be more than happy to explain it over the phone. Genuinely. I actually like talking more than writing. It allows for more dynamic conversation. PM me if you are willing to banter back and forth.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
#58
I know this is beating a dead horse and you seem to feel adamant about it, but it's a pet peeve of mine to hear an inaccuracy echoed in multiple threads. It is possible(and has been done by numerous individuals) to gut the rear cat while attached to the engine with the manifold in place.I didn't have someone else gut my cats. I did it. I don't get any merit badge for it, but I do feel I get the credibility since I've got the experience here. ![Cool](https://maxima.org/forums/images/smilies/cool.gif)
If not, I'll try to let sleeping dogs lie on this topic. Deal?
Hey what can i say i have been wrong before and im sure i will again.If it can be done it's not a smart or efficient way to do that job and not to mention all the debris from the cat getting shot and stuck up in the manifold.Love to see how much oil the car would burn after doing that either it's sketchy as heck in my eyes but to each his own.
#59
That would have been a fine place to stop, and yet...
If you like, I could give you my mechanic's phone number, and you could explain to him what is and isn't smart. However, I don't think it would go over too well. ![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
Now, that might sound snarky, but it's all in good fun, champ. And nelledge is right (again, damn him)... it's time for you to get off this horse.
#60
If you like, I could give you my mechanic's phone number, and you could explain to him what is and isn't smart. However, I don't think it would go over too well.![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
![Popcorn](https://maxima.org/forums/images/smilies/popcorn.gif)
#61
The rear cat is the one against the firewall right
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
#62
Is it OK if I admit how much I enjoy watching 036mtmax struggle with his stubborn streak? It was fun.
For perspective, this was the guy who cut his teeth on the Org six months ago after swapping 4 or 5 different gear fluids in his 6MT until he got the one that felt just right. That kind of OCD attention to detail explains a lot about why he can't walk things back.
It's all good, 036mtmax. The Org is better for having you around this year.
#63
welp didnt get much done today at all, i went out and had a hell of a night for my b-day, but anyway ill get back to this shyt in the morning... btw the rear cat is a beeeeoootttccchh to gut... the materical inside is frikin metal and no matter how much you hit it with the air chisel itll just smush together and begome a bigger mass of metal, this craps insane lol owell well see how it goes tomorrow.
#64
Dude i have never thought it was possible to see a mechanic drop as many f bombs as he did that night he gutted my rear cat
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
#65
These are the anti-foulers you want from autozone 18mm's you have to drill out the small hole inside with a 1/2 inch bit
There was two set's of 18 mm foulers there (long and short) i got the longer ones
![](http://i1180.photobucket.com/albums/x410/036mtmax/DSC02852.jpg)
#66
I love how much more simple a technique this is than using a Sim.
#67
Damn hurricane! i cant even go out side and work on the cat....i could do it in the garage but i really dont want all that dust and debris flying everywhere...i dunno maybe ill bolt up the front manifold now.. just not too motovated today :/, o and with those antifoulers you have to buy a two pack then drill only 1 of them put them both together and then screw in the o2? basically 1 pack works for 1 sensor...
#68
Drill both of them out.You put one in the y next to the oil pan which i threw a you a pic of and there's another one above that one you put the other fouler in there.
![](http://i1180.photobucket.com/albums/x410/036mtmax/2011-08-13163344.jpg)
#71
I think close to a thousand miles now, i have purposely driven alot lately to see if the cel will come back on...My mechanic checked it with his scan tool a week later and he said it's not monitoring it so i shouldn't ever have a problem with them (hopefully)
#72
#73
Hence the 180 degree bend so that the two collector pipes have an even length. The heat shield on the OEM y-pipe hides that design.
Right now, there's a whole crew of people over in that Cattman Y-pipe Group Buy who are receiving their orders this week. I'm curious how many (if any) will be gutting their pre-cats as part of the install.
Apparently there are three y-pipes still available for purchase.
#74
^^^ interesting! i really want 1 but i need to just do this shyt in steps.. next step is to put everythign back together and finish gutting the rear cat ! then ima get a test pipe then maybe the ypipe..
#75
Rochester, did you notice a louder sound or power gain at all when you did your y ??
#76
Instead of a test pipe you can always gut the rear cat while the y's down
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
#77
Anyway, looking at exhaust mods only, the history goes back a number of years:
2007 - Cattman 2.5" cat-back
2008 - Cattman y-pipe
2011 - Gutted pre-cats
The uneven length of the y-pipe immediately created a deeper tone to the exhaust, which I like. And from low-end to high, there was a small, noticeable increase in power, commensurate with the advertised gains of 8-12 HP. Also something to like.
Of course, with hindsight, I should have purchased the headers (added noise notwithstanding), but hindsight is a blind date.
#79
Well ya thats what i was going to do all along but my ypipe isnt actually "dropped" its still attached to the main cat because i still cant get those 4 nuts loose... im thinking the only way to get it off is to cut the studs and drill them all out.. what a pain in the a** that will be... and also i read that with the main cat gutted itll sound funny, any 1 have experiance with that?
#80
Im not sure if you have access to a torch to heat the bolts up but i know my mechainic had to torch a couple bolts to crack em loose and as far as gutting the main cat idk. I bought a megan racing one on ebay and cut an inch out of it and re-welded it because there made in inch bigger for some reason and it will push your exhaust tips out an inch and looks stupid.
