What do you expect to have if you've got bad TB on a 5.5 gen ?
Old Aug 24, 2011 | 11:14 AM
mahanddeem's Avatar
Hi
125k miles,NO CEL,idle is fine....Lose of power that sucks big time.
New MAF,new NGK plugs,new precats,new main cat,new air filter,new O2 sensors,new fuel filter,new nissan clutch,ECU update,Shell 93 V-power...
please do I have a bad TB ? before I sell the car
PS..If yes , have anyone an experiene with the $193.xx reman TB from DaveB ? I know he's great guy but what about his TBs ?
PS2...Sometimes when I go WOT from any speed especially slow , car does nothing like Iam not on the gas then slowly accelerate..
Old Aug 24, 2011 | 01:55 PM
knight_yyz's Avatar
Toolie
if the TB was bad you would be throwing a code for the throttle position sensor.
Old Aug 24, 2011 | 02:02 PM
nelledge's Avatar
"I'm just sayin'..."
Have you tried the relearn procedure, recently? Also, what are your driving habits? Try to be very specific with that last one.
DaveB is the parts manager(I believe this is his new title) at Southpoint Nissan in Austin, TX. He gives wholesale prices to Nissan club/forum affiliates. It is an actual brick and mortar Nissan dealer that sells Nissan parts. Purchasing a part from him will almost definitely ensure it is a Nissan part.
Old Aug 24, 2011 | 02:25 PM
NmexMAX's Avatar
dot dot dot ...
It's not a TB.
Pre cats maybe.
Old Aug 24, 2011 | 02:58 PM
nelledge's Avatar
Originally Posted by NmexMAX
It's not a TB.
Pre cats maybe.
Again?
New MAF,new NGK plugs,new precats,new main cat,new air filter,new O2 sensors,new fuel filter,ECU update,Shell 93 V-power......
Old Aug 24, 2011 | 03:24 PM
mahanddeem's Avatar
thanks everybody...The issue is stil there as chet...For nellege question I drive as everyboy does,though I don't push too hard on the peddle to avoid more headache with it,but driving from a dead stop beside a 96 Malibu or Camry and shifting around 2500-3000k rpm and get well smocked from those 2 isn't funny at all when you drive a 3.5L engine....It is too much embarrassment...
What happens is that the car in idle if fine , shifting into 1st , starting rolling , RPM gauge is climbing steady and normal all the way but the speed gain is nothing but crap , well not toooo crapy but no where near an agile active car like the 5.5 gen ... Sometimes I have to disconnect battery and it is lil better for sometime (half a day) then crap happens again...Too frustrating.
Old Aug 24, 2011 | 03:38 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by nelledge
Again?
Oh shyt. I didn't see that. I think a dyno is on order.
I agree, IAVL may or may not help.
What reflash was this?
Old Aug 24, 2011 | 04:14 PM
made in china's Avatar
The 3.5 TB is drive by wire. It will go into limp mode if there is a problem detected. The TB has two potentiometers (TPS) one goes up in resistance and one goes down in resistance as the throttle opens (for double checking) and one throttle motor. If anything doesn't seem right the ECU should throw a code and limp home is severe, the car won't get up to any road speed. I had it happen to me one time, not cool. Anyways, a TB should be obvious....
Old Aug 24, 2011 | 04:22 PM
spock's Avatar
I know this sounds elementary, but clutch? If the revs go up and the speed doesn't...
Old Aug 24, 2011 | 05:35 PM
mahanddeem's Avatar
new clutch and s cylinder
Old Aug 24, 2011 | 05:47 PM
nelledge's Avatar
I'd love to see a short video of your cluster while you're experiencing the problem. Sound would be nice, too, if possible. What do you think? Wanna take it for a quick spin around the block? Show us some WOT at least once.
Old Aug 24, 2011 | 06:36 PM
spock's Avatar
Yea, more info required. How many miles, does it use oil/puff smoke? Is it a dog out of the hole with power spurts, or just sluggish all the way?
Had the timing checked? Any issues with knock sensor? Lots of variables @ this point.
Old Aug 24, 2011 | 08:31 PM
mahanddeem's Avatar
If I'm not mistaken some bad or near-bad MAFs don't light the CEL...Which I assume more complicated elec. parts than TBs.
Old Aug 25, 2011 | 06:22 AM
NmexMAX's Avatar
dot dot dot ...
This thread title should be changed, it's totally not the TB. It's been covered in here by many.
If you already had the MAF changed & ECU reflash because of it, it may be something else. A video would suffice here.
Old Aug 26, 2011 | 03:30 PM
long shot here, but a common maxima problem: check your rear brakes to make sure they are not seized. Mine seized on my car and it really does slow the car down a bit.
Old Aug 28, 2011 | 06:07 PM
mahanddeem's Avatar
I will check for that..Thanx.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaxStock
Aug 12, 2015 08:33 AM
