sun roof not working:(
Old Aug 29, 2011 | 01:24 PM
NewMaxx's Avatar
Alright after this crazy weather in new england, the weather today was amazing... so while I was driving I put all my windows down and reached up to open the sun roof, NOTHING happened... so I was like wth... so banged the sun roof few times from inside and out... but no luck....Please I need help... can it be the fuse? Help asap
Old Aug 29, 2011 | 03:48 PM
kbcnd's Avatar
Does the vent switch work?
Old Aug 29, 2011 | 06:00 PM
LongoTE's Avatar
Hold the vent switch forward and then backward for 10 seconds each. That should reset it.
Old Aug 30, 2011 | 02:48 PM
bocian's Avatar
^ just did that too like 2 days ago, all theres to it!
Old Sep 1, 2011 | 05:50 AM
NewMaxx's Avatar
Nope
Old Sep 1, 2011 | 05:52 AM
NewMaxx's Avatar
I tried 10 20 30 seconds each but no luck... hmmm I had no problems before... wth
Old Sep 3, 2011 | 06:41 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Drop the control switch and ensure the connector hasnt separated from vibrations. I actually ziptied mine due to the subs vibrating it loose multiple times
Old Sep 3, 2011 | 10:23 PM
hockeydoody's Avatar
mines broke also.
oh well, it's too hot to even have the visor open, especially with black leather seats.
Old Sep 4, 2011 | 03:38 PM
00MaxMayne's Avatar
Mine has been starting to act up a bit. I hope its not going completely bad. But when I open it, or attempt to, it moves about half an inch then stops. Then I press the button again and it moves another half inch then stops... I've just stopped using it all together in fear of it getting stuck.
Old Sep 5, 2011 | 12:35 AM
X01MAXIX's Avatar
Try to disconnect the battery for half hour. Mine was doing the same thing and I did that and it started working
Old Sep 5, 2011 | 06:51 AM
kbcnd's Avatar
Sounds like it only works with the vent switch and not the slider eh? If that's the case, it's not dying on you, you just need to do the reset.
Open the sunroof all the way using the vent switch, pushing it as many times as needed, then close it completely using the vent switch. Once closed hold the vent switch in the roughly 10 seconds and then release. Try to open it using the slider, should work as normal.
Old Sep 5, 2011 | 02:59 PM
00MaxMayne's Avatar
It does it when I use the vent switch or the slider. But I'm gonna try the reset method and hopefully that works. Thanks!
Robert Schneeweis
Jan 11, 2017 06:47 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Vequity
Sep 10, 2015 05:26 AM
13Maximasv
Aug 7, 2015 10:56 AM
