2002 MAXIMA INSTALLED A TRANSMISSION COOLER
I decided to go with well known & recommended tranny cooler radiator supplier, instead of some ebay supplier from Asia. I am running this in a series along with the radiator tranny cooler. This unit is designed for a Gross vehicle weight to 18,000 lbs. So i figured this would be MORE than enough for my 2002 Maxima GLE. As i posted before with a tow hitch install write-up(posted below), i will be towing mine & wifey's 2 race bikes to the track every couple weeks in the warm months- so this is a great investment.(its even a great investment for anyone who doesn't tow, but spends time in traffic- which i do often to wine & dine HER in nyc lol)
INFO FROM THE HAYDEN WEBSITE:
Rapid-CoolŽ Transmission Oil Coolers
Rapid-CoolŽ’s unique plate and fin design offers excellent cooling efficiency in a compact, space-efficient design.
Features
![](http://aaamanag.angelfire.com/MXIMA1.jpg)
Just to get a relative comparison on size. With my fingers spread behind it, my palm is completely hidden.
![](http://aaamanag.angelfire.com/MXIMA2.jpg)
![](http://aaamanag.angelfire.com/MXIMA3.jpg)
![](http://aaamanag.angelfire.com/MXIMA4.jpg)
![](http://aaamanag.angelfire.com/MXIMA5.jpg)
![](http://aaamanag.angelfire.com/MXIMA6.jpg)
![](http://aaamanag.angelfire.com/MXIMA7.jpg)
![](http://aaamanag.angelfire.com/MXIMA8.jpg)
![](http://aaamanag.angelfire.com/MXIMA9.jpg)
![](http://aaamanag.angelfire.com/MXIMA10.jpg)
![](http://aaamanag.angelfire.com/MXIMA11.jpg)
![](http://aaamanag.angelfire.com/MXIMA12.jpg)
![](http://aaamanag.angelfire.com/MXIMA13.jpg)
FOR ANYONE INTERESTED IN A TRAILER HITCH WRITE-UP:
http://forums.maxima.org/5th-generat...02-maxima.html
Features
- 33% more efficient than a comparable tube and fin design
- Pre-drilled mounting plates for easy installation
- Four sizes available to fit a wider range of applications
- Internal turbulation for efficient heat transfer
- 3/8” push-on fittings for quick and easy installation
- Overall Height 11in.
- Overall Width 6in.
(strange thing happens after all day in the city- and ambient temps are in the 90's: On the way home the tranny tends to hold the gears a little longer. So after the weekend in the city, and on the way home if it doesnt do that weird thing anymore- i will feel a difference. but for now nothing.)
oh sorry forgot to mention- the cost of the unit was $42 after 7% sales tax. it comes with a whole bunch of things, but the hose it came with proved to be to short for the application. so i went and got 4extra feet of hose for an addition $8. that was the total cost of this simple project.
to be 100% honest, you wont feel a difference. the only difference you could see would be in numbers if you took the temps of average running conditions prior to install, and then after install. I just finished an hour or so ago, maybe i will see a difference after spending all day in NYC traffic, and then an hour in a half drive home on the highway.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
nope, looking to tow wifey's and my track-bikes to the track.
TRAILER HITCH INSTALLED ON 2002 MAXIMA
I did Hayden 404, and if im not mistake is almost double is size. and in my case you need 6 extra qts of tranny fluid.
![devil](https://maxima.org/forums/images/smilies/devil.gif)
and i have to say, you know sitting in traffic when you start moving and its about to shift to the higher gear- and just at that moment you hit the brakes?
that kinda confused tranny jolt? - ITS GONE.
i tried to simulate that feeling... and its gone man. i thought i was crazy, having fisherman tails to tell... so i kept quiet- now that you said how yours shifts smooth as butter- i figured id share my story.
MY VERDICT: THE TRANNY REALLY DOES SHIFT SMOOTHER.
you said you did the 404 - i wanted to make sure i had the plate style versus fin style. heard that the plates dissipate heat faster for the ATF.
your style of cooler is good for oil- it wont decrease the line pressure.
well im sold lol, that happens to me all the time,ill b getting one very soon now.thanks man
you know this morning driving to work (45min commute) i got a chance to mess with the tranny a lil ![devil](https://maxima.org/forums/images/smilies/devil.gif)
glad i could share the process.
i think this is a great bang for your buck.
every tranny website i visit all claim every 20degree's shaved off the temps- is like doubling your tranny life. and with these cars being kinda old already; i think preserving important components like the tranny should be the most important thing on anyone list.
sorry homie- you guys dont have the same tranny.
you have a gear oil- versus ATF. you dont have valves, or seals either.
your clutch is a dry plate, while we automatics have wet clutch packs. and if this hot fluid make the clutch packs hotter, they over heat and begin to degrade & slip.
further more the fluid that runs our hydraulics will degrade the valves & seals if its over heated. the fluid then causes what almost is like blood clots and jams hydraulic lines, etc.
with me living in the south, I went a different route. I bypassed the rad cooler and took it straight to the tranny cooler. Also, to avoid problems, I ran steel tubing instead of rubber lines. If you have a tube bender, or can rent 1, it is better. The only rubber is short pieces going into the cooler and into the tranny. Looks alot neater, went thru a hole in the lower rad support..... Plus, alot stronger if you run over anything in the road
well i have a splash shield so that will protect the hoses from anything i run over-
and id like to rebuttal your strength claim:
if i run over OOOOH LETS JUST SAY: a coyote(for a silly example) and the SOB bangs into the splash shield, and bends your metal ATF pipe and causes a pinch- say good bye to the tranny.
now if i run over the same coyote and the SOB bangs into my rubber piping... the rubber(like a tire hitting a pothole) will recoil back into its original shape. so in fact, your positive claim to having a metal pipe is actually a downfall.
case in point:
![](http://davemark.com/images/coyote.jpg)
![](http://thegreatwhitehunter.files.wordpress.com/2009/11/coyote-roadkill-survivor-4.jpg)
PS: THE COYOTE SURVIVED WITH JUST A SCRAPED PAW lol
case in point:
case in point:
case in point:
Also, using a tubing system with rubber hose it's practical a best option than a all metal tubing because if you suffer a pinch it's even more easy to replace a rubber connection than a metal connection.
Ok, so let's make this clear
Benefits of get a transmission cooler
- Lower working temps
- Smooth shifting
- Increase life of transmission and ATF
- Ideal for cities with "Hot as Hell" summers
- Ideal for city driving
The "bad" things
- Hard shifting in cold places for the few first miles
- Almost 6 qts of extra ATF
Conclusion: I'll make this mod this weekend![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Thanks ImStricken for the How To
- Smooth shifting
The "bad" things
- Smooth shifting
The "bad" things
- Smooth shifting
The "bad" things
![highfive](https://maxima.org/forums/images/smilies/highfive.gif)
now that u said that I was thinking about it, and I needed 6 qts for a flush!
, I do rememeber supplying 6 qts though for the full amount of a flush and they still needed more due to the way the machine flushes.
nice write up op, and im interesting on to your theories with the fin vs plate style. Is it just opinions?
Im confused only because the Hayden 404 is for transmissions?
not to be picky, and i don't want to offend but, where the trans lines go into the radiator, that is a cooler it is going to. but what you did was eliminate the oem one that always has 195 degree water surriounding it, to an air-cooled model. does it really benefit that much? if so i amthinking about doing this to my girlfriends pilot lol seems like a good idea...
its just below the rad, and also getting air cooled. but i wanted something a little more on top of it. so i piggy backed a new cooler
this is my set-up: TRANNY -> RADIATOR TRANNY COOLER INLET -> RADIATOR TRANNY OUTLET -> new tranny cooler inlet -> new tranny cooler outlet -> TRANNY
this way im still using the OEM setup but added (via an inline formation) a new tranny cooler that will cool the tranny fluid down even ore
I HOLD NO RESPONSIBILITY TO THIS VIDEO. I DIDNT MAKE IT- I JUST REMEMBERED HE DID THIS TO A PILOT.
http://www.youtube.com/watch?v=Ufns-kpwHJ0
Nice write up.
IF u did not want to use a Hayden 403.
The B&M part # is 70264 or 702648
Magnefine inline filter
Link: http://www.emergingent.com/subpage1Magnefine.htm
It helps cool the transmission fluid so it doesn't cook and make your automatic transmission take a big expensive s**t. If you ever smelled burned ATF you'll know exactly what I'm talking about.
![+1](https://maxima.org/forums/images/smilies/+1.gif)
further more, since auto tranny's dont just go in 1 shot(its more of a slow downward progression)
before they do take that big expensive ****, they slip, bump, and jerk because the thin fluid gets even thinner when hot.
that hot fluid then transfers the heat to anything it touches- and accumulates more heat from anything it touches- thus increasing heat in everything and further degrading internal components.
so for those that dont tow, or abuse their cars- this is still a great add-on to any car because it will cool the fluid down even further than the stock cooler can, thus further preserving precious seals/valves/clutch-packs. also since fluid is naturally thicker when cold- it creates more pressure for the valves to operate in - thus resulting in smoother shifts while driving. so for us gen5 owners with obviously not so new tranny's this is almost a mandatory upgrade. this will preserve our trannys and allow for further service life.
plus if you did upgrade your horsepower; the tranny is really what takes all the raw power and transfer's it to the wheels. so if the engine gets upgrades - so should your tranny. (otherwise you will blow out your tranny)
ImStricken... I will say it again: This mod it's AWESOME!
I just read information about the OEM filtration system in the A/T and I'm scared of all the debris and sh*t that will form in it. I know that our cars got a screen filter and 2 magnets that catch a lot of that debris but I don't see a reason for why we can't install an inline filter, even it can be installed before the OEM cooler to prevent the deposit of debris in it.
This will be the route for a better transmission filter/cooler system
transmission -> output hose from the transmission -> inline filter (like magnefine) -> OEM cooler -> air cooler - input hose to the transmission -> transmission
We'll need more ATF but our cars will be happy for this upgrades!![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
What do you think about this configuration?
now regarding your configuration; iv always known that filters are to be installed in the return line AFTER the cooler. i read their website & magnefine pretty much confirmed my thoughts:
"On new vehicles (less than 5,000 miles), it is recommended that the filter be installed on the cooler supply side to protect the cooler from contamination. On in-service vehicles (more than 5,000 miles), the filter should be installed in the return line from the cooler to the transmission. On any vehicle that has experienced any transmission difficulty, the filter should be placed on the return side."
If you reside in areas that see cold winters, below 40 degrees....you should consider installing a thermostat so the fluid can get to operating temps before being primarily cooled through the cooler.
(I say primarily cooled because thermostats tend to stay 95% closed until operating temps - allowing only 5% open/flow to avoid air bubbles and build up of contaminents at the thermostat - then when at operating temp, the thermostat opens to 95% flow).
Perma-cool has a really good thermostat. I think Summit carries them...in-expensive.
