vibrating clutch fork?
Old Sep 4, 2011 | 01:09 PM
dnice02's Avatar
Need a little help. i finally started the car up on yesterday, and i noticed that the clutch fork is vibrating back and forth. also i feel the vibration when i step on the clutch pedal. any thoughts on what could possible cause this?
Old Sep 5, 2011 | 05:54 AM
StevieB's Avatar
adjustment
Allright, I'll share my thoughts on this one since nobody is biting. Your sig lists a 6 speed swap, so clearly you've had the tranny off the engine.Did you install new clutch components-especially the throwout bearing? If by vibration, you mean the fork is loose and the play is causing a slight rattling, then I'd guess the pivot ball for the fork is not adjusted to the correct position, the fork cup where the fork contacts the pivot ball is damaged, or the fork is bent. All these situations might result in play at the fork and vibration. Good luck!
Old Sep 5, 2011 | 06:47 AM
dnice02's Avatar
Thanks for the help. I do have all new clutch components. How do you adjust the pivot ball?
Old Sep 5, 2011 | 10:08 AM
maxspeed96CT's Avatar
The original VQ...
The clutch fork does vibrate a little normally. Not violent vibrating though . If it seems more then normal sounds like your clutch/fly wheel might be unbalanced..
Old Sep 5, 2011 | 12:14 PM
dnice02's Avatar
do you mean as in the alignment?
Old Sep 5, 2011 | 01:27 PM
The original VQ...
No I mean balanced. Most people normaly never do it ( I never have ) , but aftermarket clutch setups can be balanced almost like a wheel.
Google it for more info I dont know the details.
how bad is the vibration?
Old Sep 5, 2011 | 07:28 PM
dnice02's Avatar
I can look at the fork moving back and forth. Also when I depressed the clutch pedal I can feel it in the pedal.
Old Sep 9, 2011 | 04:18 PM
dnice02's Avatar
Here's what I have guys the clutch pedal feels good while the car is off, but when I start it, I loose pressure.
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
