Two lights flashing on dash..Help
Ok the other day my Battery light and brake light came on flashing,They flash for 2 to 3 seconds at a time then i wont see the them flash for about 5 to 10 mins,Now i have done charging tests on both the battery and the alternator,I also replaced both belts(They both seemed worn and streched),I thought that would clear it up.The funny thing is there is no performance issue the car runs fine,It doesnt stutter or idle funny at all,Can anyone give me any tips as to what is causing this and what to do to correct it
Those lights are the indicator for a failing alternator. Sounds like it's starting to give you an issue but not quite showing up on tests. Just monitor it. You'll likely need a replacement soon.
Also, check all your power connections - battery to starter, battery to alternator, grounds, etc.
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
