Will 5th Gen Auto Motor Mounts in 5.5 Gen Manual work?
I'm most likely only doing the front mount, maybe the rear. I know the transmission mount won't work
Did some research and I knew that when Auto mount's go bad, some people tend to replace them with Manual mounts for a few reasons.
I also saw someone mention that short of the tranny mount, it is OK for an auto from 95-03 to use a manual from 95-03. Since I can get a free good condition OEM mount to use, I figure I'll take advantage of it.
Can someone please verify that I can use the Auto mount from a 2K1 on my 2K2 6MT?
I know I'll just leave the mount unplugged, but I believe someone mentioned that the rubber inside (or inserts?) is a different size. Would this make any difference?
It'll work, the center of the mount is still in the same location.
But more importantly, why?
It takes a lot of work to remove the crossmember and replace the mount...you can get all 4 mounts for like $110, shipped.
Seems as if you're going backwards here. Most of us autos use the MT mounts.
They are very cheap and there's no reason why you would do what you're doing, so I agree with dj.
The auto mount is larger diameter than the MT mount, so with that said the AT bushing is larger than the MT bushing because of this.
What research did you do to come to this conclusion?
I'm assuming you guys are referring to the ebay mounts.
The main reason why I'm doing this is cause of time. I'm trying to get this done tomorrow or friday and it's readily available for free. The rest of the mounts are in good condition as far as I know. The labor charge for it will be very low coupled with other stuff I'm having done.
I know the MT and Auto mounts are interchangeable for the reason that you mentioned that many go from Auto to MT mounts.
I know that the 95-03 mounts are interchangeable from reading some thread where someone mentioned (forget who at this point but I know it's someone that frequents the forums) that short of the tranny mount, the mounts holding up the engines are the same since the difference from the 3.5 to 3.0 is bigger bore, among other things that don't affect how the mounts hold them up.
Nmexmax, are you saying that due to the different sizes in the bushings, I shouldn't be able to use it in my 6MT?
I was under the impression that it would work and I'd just have an unnecessary connector which apparently djfrestyl seems to agree with.
Edit: Not sure which ebay ones you guys may be referring to since there are alot. Or did you mean from somewhere else?
Which I'm pretty sure it is, and if so then yes it will work.
^^ Correct. I'm talking about the entire mount, not just swapping one bushing into another bracket.
Also, there's nothing wrong with the eBay mounts. I've installed a half a dozen sets of them.
Yes, I believe they'll be taking the entire mount off of the AT with the frame, and replacing it rather than taking out the bushings.
Are they that bad?
Not sure how true this is but I can say that with an auto w/ a stage II.5 VB mod, the PUR mounts were the single best mod to accommodate this VB mod.
Initially, I had even gone so far as to order a lower grade VB mod, but then decided to install the PUR bushings as a last resort, and WOW!!! Shifts are amazingly smooth now, but crisp as can be. With the OEM AT mounts w/, it felt like something was wrong, it would slam shift into gear and feel really bad.
I think the Auto mount is softer than the manual mount especially without the motorized function. I think your engine will be very sloppy during shifts.
Can you justify that in a better way knight?
Turns out the person I mentioned earlier in this thread who said that the 95-03 mounts all fit was you I believe.
I don't usually doubt you knight, but I would rather some more concrete proof if at all possible. As of now I get some vibrating at idle and through visual inspection, the front mount is bad.
Would doing this really potentially make my car worse..?
No one would have quantitative proof, and at this point, you're splitting hairs.
Get the work done tomorrow and let us know how it goes.
Finkle
Sep 27, 2015 09:53 PM
MaxStock
Aug 14, 2015 10:03 PM
