Some Lowering Spring Questions
So I've been looking into getting some lowering springs but I've got a few questions. I was trying to compare the spring rates but I couldn't find one for the Eibachs. I'm hoping to go as low as possible but stiffness/ handling is more important to me. Also, I read something about needing to get aftermarket struts when getting stiffer springs. How important is this? Coilovers really aren't an option for me since I'm on a pretty tight budget right now.
Thanks!
Thanks!
What you want can only be had with Coilovers. If money is tight, then wait until it's not.
You may want to do some more research on the subject in the Suspension forum, or, search for threads started by irish44j and housecor, among others, but from what they 2 aforementioned members have posted, I'm sure you can find some other links as well as other knowledgeable members.
So basically if your just trying to get lowered on stock struts, then you have to do a mild drop or you will probably blow them out. Thats why people are saying get the coilovers.
So since your on a budget than spend about $200 on eibach prokits or teins h springs.
When you do it right, you get Illuminas or something similar and springs.
BUT that combo cost upwards of 500$ w/o install. At that point, coilovers look more within reach.
Had I done my suspension later in the Maxima world (did them like 5 years ago) I would have gone w/ coilovers... Hell, I still might just do that.
Everyone here that is suggesting coilovers to you are correct.Look at it like this by the time you spend $300-$500 on struts then purchase the Mounts,Bellows and etc. your going to be in the coilover price range.and just my personal suggestion do not get Tein S-Tech springs just because you want that drop. i had tried 2 different struts with those springs and the struts just could not take the abuse and i ended up going coilovers.
1. Safety
2. Performance
3. Looks
If you're priorities are somehow flipped in the other direction, then you need to start over with a different car, or find a more realistic hobby.
/oldmanrant
2. Performance
3. Looks
/oldmanrant
I had S-Techs up front and Progress rear for a while. Wow.. front was crazy bad
Even after I trimmed the bumpstops, they would hit.
1.) Too low of a drop
2.) Little suspension travel to begin with
3.) Too soft of a spring to handle it.
All those factors give one dynamic, BAD.
All that being said, if I had time to save up the money and an extra ride in the garage for transport during maintenance downtime, I would buy the coilovers.
Hmm so what I'm getting from this is that it's probably best for me to go with some sort of lowering springs + Illuminas. Might not be for a while but it's not a problem since I did replace OEM struts about 20k ago.
And that's exactly why I want to put coilovers.
My mileage went from almost 12-15k/year, to less than 1k ..
She's garage kept now.
But, as for the subject at hand, when budget is tight, stop modding and take care of the more important things in life.
She's garage kept now. But, as for the subject at hand, when budget is tight, stop modding and take care of the more important things in life.
Just one clarifier here. Your spring determines your strut. Illuminas are great - they're strong, versatile, adjustable. However you don't need to go with Illuminas if you only go for a moderate drop, such as H&R's, or Eibachs. For these two springs, KYB GR-2's will suffice. They're not adjustable but they're more than adequate, and they're HALF the price of Illuminas.
My next suspension mod is going to be Springs (Eibach) and Struts (KYB GR-2 or Tokico "Blues"). I've read a lot of conflicting info on the .org re: these 2 strut/spring combinations. Can someone PLEASE give me a definitive answer to which strut has the best damping characteristics for better cornering performance with Eibach springs?
He simply said, "Please... please, I need to live." It was the "please" that caught my memory.
From what I've observed based on Org hearsay, GR2's and Blues are best paired with OEM springs, otherwise their lifespan is adversely affected. Tokico Illumina's are a popular choice with aftermarket springs. And their damping is adjustable. Of course, you're spending a little more, but this seems like the appropriate place to spend just a little more than your current plans.I'm no expert, and my only direct experience is with Blues and OEM springs, but that's the opinion I've formed on this very basic question. (Best to slip these questions into existing threads, Bob. Good move.)
on that one.Everyone is interested in ride quality. It's just that "quality" means different things to different people.
But as you say "based on .org hearsay "Blues" and GR-2 should only be used with stock springs." Which I've read, but also all other kinds of conflicting info. I.E. I've read that either can be used with less than 1.5" drop, or that GR-2's are designed to work best with approx 1"-1.5" drop, "Blues" are damped "softer" than GR-2's and vice versa. "Blues are the OEM equivalent to SE struts and GR-2's are equal to GXE struts (which contradicts the GR-2/"Blues" "stiffer/"softer" theory) Believe me, I've searched and looked everywhere for an answer and all I see is subjective opinions. It's VERY frustrating!
All you're going to get is subjective info, this is a user forum, not a strut manufacturing laboratory....
The ONLY differentiating information you're going to get is one-off anecdotal experience from single users, or more 'expert' experience from those that have done more than their own vehicle.
Here is my experience based on the countless suspensions I've diagnosed, fixed, installed, experienced.
YES, both Blues and GR-2's are designed as OEM replacements. That being said, there are differences between them that allow the user to vary their application to anything other than OEM.
For example, because Blues are known to be as soft as OEM, many use them to offset the stiffness of Eibachs - with positive results. Or, because KYB's have a stiffer dampening rate, they can handle moderately dropped environments without degrading their lifespan.
So, my 'subjective' advice is this. Rochester, I agree, everyone cares about ride quality. BobPezz if you're certain you want to go with Eibachs which are known to be stiff, you can take EITHER Blues or GR-2's. Why? Because the soft Blues will offset the stiffness of the spring and lead to a comfortable ride. Your tradeoff will be lifespan - which cannot be predicted or measured. They can last 30k miles or 90k miles. Otherwise, if you're willing to deal with a slightly jarring ride, then go with KYB's and they'll likely last longer than Blues.
Oh, and don't forget front Moog mounts and OEM boots (all 4).
First off, I previously owned a 79 Ford "Bronco" (aptly named) 4x4 with the off road ("Quad" front shocks & F/R sway bars) "handling package". Upgraded with "Rough Country" 2.5" lift kit and rear 3/4" thick "Add-A-Leaf's", essentially increasing 1/2 ton suspension to 1 ton rates. So I can live with a "slightly jarring ride!" That being said, based on your recommendations, I'll go with an "Eibach/GR-2" setup. Since I'm looking for a minimal drop, with improved "body pitch/roll" characteristics. To "tighten up" the IMHO "floaty feeling" OEM suspension. Does this sound like a good plan?
Could you elaborate on the need for OEM boots and Moog mounts (do you mean FSB) if so, that's in the plan with ES FSB bushings.
dj is talking about getting Nissan parts for the strut/shock boots. You're wasting your money buying aftermarket because they don't fit well. The Moog mounts he's speaking of are the front strut mounts. I used them and they work great. You can probably forgo the rear shock mounts. I bought new replacements, but they weren't needed. You'll see when you drop them down.
http://www.energysuspensionparts.com...od=MOOG-K90655
So it's true that C/Os when compared to springs/struts over time need more tlc??
once again a spoonfeeding thread title turning into a somewhat decent thread.
good luck OP and keep us posted on what you do
I've got this same set up. I think it's exactly what you're looking for. LMK what pricing you get and I can can compare it to what I paid.
LOOK, I replied without air quotes! OK so I used some parenthesis, does that count?
Sprint Spring and Illuminas , Sprints are a 1.8'' drop all around ( some say 2'') they are also an progressive springs and good for driving fast on the twisty road. I had that combo on my 4th gen with blues and never bottomed out. Rode on them for about 3 year without any real problems.
I noticed that myself! I went really overboard on this mornings post. Maybe too much coffee? Thanks, I try to plan things out. BTW; I checked out the link for the Moog strut mount. When I typed in the search for my 2001 it came up with some pretty neat stuff to improve the suspension. Got me thinking about urethane front/rear control arm bushings, sub-frame mounts and other such things to firm up the undercarriage. I was slightly disappointed that there were no replacement bushings for the rear transverse link, my lower one (drivers side) looked pretty dried out and cracked when I was under there. Best I could do at the time was spray all the link bushings with silicone.
This is what I had come to conclude, thanks for verifying.
No the springs are the same for all models, it's the dampers that are different.
ALL of the springs available for our cars are progressive springs, except SOME coilover setups which use linear springs. This thread is going good, please don't comment on something you know nothing about.
