Massive oil leak?
Old Sep 21, 2011 | 06:08 PM
cmd26's Avatar
Massive oil leak?
I got an oil change a few days ago when I checked the bill it said I have a massive oil leak. I never see oil on the ground or on the engine anywhere plus my car rides good, so where would the oil be going or are they bsing me?
Old Sep 21, 2011 | 06:25 PM
02pearlmax's Avatar
Check the level on the dipstick. Drive normally for a week or so, then check again. If its at the same level, then they were lying to you.
Old Sep 21, 2011 | 07:01 PM
mrjamaica98mx's Avatar
look under car I have same prob but I c no oil on ground
Old Sep 21, 2011 | 08:08 PM
BigLou55's Avatar
you could be burning oil as well...which you would see a leak then. jus do as pearlmax said
Old Sep 21, 2011 | 08:11 PM
Rods03Max619's Avatar
Probably got a oil burner, I had one on my 03 put 5 qts in after 3000 miles change oil and get like 3 1/2 out, till engine croked out like 155k, got a 04 engine and no more oil disappearing it was so nice to see all the oil come out...but ride got totaled ..2 months later...
Old Sep 21, 2011 | 08:36 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Should also be thinking about the precats. No oil burners turn into dead oil burners real quick.
Old Sep 22, 2011 | 06:40 AM
ImStricken's Avatar
check the seal on your oil pan. its a common issue.
Old Sep 22, 2011 | 06:49 AM
rroderiques77's Avatar
Demodded and Forgotten
A massive oil leak isn't a burner. And just because you don't see oil on the ground doesn't mean it is not leaking.
Start checking at the rear v.c. and work your way down. Use dye if you have to. Keep in mind you may also have another fluid leak other than engine oil, i.e. power steering, etc.
Old Sep 22, 2011 | 07:34 AM
altezzablazes's Avatar
Check you intake manifold if u have a vq35. If you see puddles of oil in the manifold. Chanhe your pcv valve.
Old Sep 23, 2011 | 02:14 AM
Todd Gack's Avatar
How worried should I be about the beginning of a leak at the main seal? The mechanic said its not dripping, just some moistness around the seal, but because of the labor involved he quoted about $1200 to take care of a rear main oil seal. Car has 108000 miles, recently bought it (2000 GLE). He said it was something to be concerned about over the long haul but not something that would prevent the purchase if a good deal.
Old Sep 23, 2011 | 11:53 AM
BigLou55's Avatar
^^^^sure its the rear main seal and not the upper oil pan?
Old Sep 23, 2011 | 01:24 PM
Todd Gack's Avatar
mechanic said it was possible rear main seal, but since it was just a used vehicle inspection and he didn't take things apart to get back there, that is not written in stone. He did say nothing is dripping, just some oil residue, and it was not an immediate red flag but something to keep an eye on
Old Sep 23, 2011 | 01:50 PM
I am pretty sure on you have to remove the upper pan to get to the main regardless.
I wouldn't worry about it if it is just moist around it.
Old Sep 23, 2011 | 03:23 PM
Matt93SE's Avatar
STFU n00b!
rear main seal requires tranny removal to replace, but it easy to do once you're there. the seal & retainer bolts onto the back of the block with a paper gasket and seals against the oil pan. very common to leak, but it's usually the lip seal around the oil pan, not the rear main seal itself.
personal practice is to change them every time I do a clutch job.
Old Oct 6, 2011 | 01:30 PM
cmd26's Avatar
I found this next to the oil filter
Old Oct 6, 2011 | 01:34 PM
phatboislim's Avatar
clean it then get back to it...could be something as simple as the old oil filter gasket being stuck on
Old Oct 6, 2011 | 09:31 PM
ImStricken's Avatar
dude 99% its your lower oil pan. these cars for known for it.
wipe it clean and see where its coming from. this is due to rust building up on the pan, and eating the metal up. check around the bolts, and the pan itself.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
