240sx 3" test pipe vs. Megan Test pipe
Old Oct 7, 2011 | 08:02 AM
joesae01max's Avatar
So I bought a megan test pipe from a fellow .org member and let me tell you the Fitment was HORRIBLE. It was like 1" longer than OEM. I was not Pleased with it at all - so i remember some one here used a 240sx test pipe and it was the same exact size as OEM.
So sure enough, I looked it up and its 12 3/8th". I ordered it that same day off Ebay and got it yesterday. IT fit Like a glove.
Here are some pics for comparison to help anyone out.
Left is 240sx 3" pipe - middle is Cattman Fast cat & right is the Dreaded over sized Test Pipe.
Notice how the 240 pipe is the same exact size as the cattman fast cat.
Old Oct 7, 2011 | 08:07 AM
That 240 test pipe looks delicious.
Old Oct 7, 2011 | 08:54 AM
luvlexus101's Avatar
http://cgi.ebay.com/ebaymotors/Nissa...ht_4145wt_1165
Yeah?
Old Oct 7, 2011 | 08:58 AM
03VQMAX's Avatar
Found it!
http://cgi.ebay.com/ebaymotors/3-Res...item5645e88d72
Old Oct 7, 2011 | 09:01 AM
That one would work, you just have to get ride of those hangers luvlexus101
Old Oct 7, 2011 | 09:03 AM
Originally Posted by 03VQMAX
Yup that's it.
Old Oct 7, 2011 | 09:04 AM
03VQMAX's Avatar
To the op, are you pairing this up with aftermarket headers?
Old Oct 7, 2011 | 09:07 AM
Yes, its paired up with Cattman Headers/Y and a Cattman 3" Exhaust.
Old Oct 7, 2011 | 09:11 AM
aackshun's Avatar
This thread = winning.
Buying it.
Old Oct 7, 2011 | 09:15 AM
Probably cheaper to find one on a 240 forum HM
Old Oct 7, 2011 | 01:22 PM
Xpcgamer's Avatar
I got the Megan and had it cut and rewelded. Cost me another 15 bucks. I'm not ready to go 3" yet!
Old Oct 7, 2011 | 03:29 PM
Rods03Max619's Avatar
NICE....did you feel anything on the butt dyno when switching from the Fastcat to the Testpipe and do you got any Vids....
Old Oct 7, 2011 | 04:13 PM
fishtale6spd's Avatar
Hey so I got stock y pipe and 2.5 catback will this still bolt up even though its 3"
Old Oct 7, 2011 | 04:17 PM
nishfish871's Avatar
ahh yes the 3" 240sx test pipe. The cheapest one on ebay fits perfectly (non-resonated). I used the stock y-pipe gasket and the supplied gasket, then the supplied gasket and 3"brm gasket for that. No leaks at all, have to say though, the sound is louder. I'd suggest buying the resonated version...
Old Oct 7, 2011 | 05:34 PM
I did, throttle response has improved. I need to get this thing dyno'd soon though. I'll try and make some vids this weekend. Sounds really good.
Yes it will bolt up fine - it's just your not really gonna benefit from it cause you going from 3" to 2.5" piping
Old Oct 7, 2011 | 05:38 PM
Ya and The fitment was perfect
Old Oct 7, 2011 | 06:09 PM
maxspeed96CT's Avatar
The original VQ...
Can anyone measure the center to center bolt holes on the 3" 240sx test pipe.
Reason is I have OBX headers, and id like to leave them the way they are and then go 3" after that without hacking up the headers.
So any flange and bolt hole measurements would be very helpfull. Thanks guys.
Old Oct 7, 2011 | 07:41 PM
I'll get you the measurement tomorrow. It's exactly the same as the cattman fast cat - holes line up perfect.
Old Oct 7, 2011 | 08:22 PM
McSteve's Avatar
I have OBX headers and had a cattman fastback installed. switched it out with warpspeed test pipe and fits perfect. I'm gonna get myself one of these later on.
http://intensepower.com/mera3sttepi.html
i believe they have a nicoclub group deal going on for 65 shipped
Old Oct 7, 2011 | 10:06 PM
schmellyfart's Avatar
You don't need to hack up your y pipe to bolt up the 3" 240sx test pipe.
Old Oct 8, 2011 | 09:22 AM
^ he's right. but if you still want the measurement i'll get it to you MAXSPEED96CT
Old Oct 8, 2011 | 09:40 AM
maxurlife's Avatar
I have the fast cat coming. is the 240 test pipe the more HP producing route or is it just a cost savings (which is a huge difference)?
Old Oct 8, 2011 | 10:13 AM
^ with your 3.5 you'll get the added HP with the test pipe. Won't be much but you will get it.
Old Oct 8, 2011 | 10:37 AM
McSteve's Avatar
Why only with the 3.5?
People are acting as if the .5L difference in displacement totally negates the same basic principles of physics that are the foundation of car tuning.
Eliminating restrictions WILL benefit everyone. Even on a 1.8L engine.
Old Oct 8, 2011 | 10:53 AM
Both.
Old Oct 8, 2011 | 11:17 AM
Very true - what i meant was you see more gains with the 3.5 than the 3.0
Old Oct 8, 2011 | 12:49 PM
MrEous's Avatar
^ Jeff™
I don't believe that to be true...well, not a 1.8l engine with a 3" exhaust anyway. Too much tq lost to really see benefits.
Old Oct 8, 2011 | 03:36 PM
McSteve's Avatar
I think that has been conclusively disproven.
On most cars without a proper AFr tuning apparatus increase flow will cause the engine to run leaner and therefore to lose torque.
I highly recommend reading this
http://www.veryuseful.com/mustang/te...Scavenging.pdf
....However, Wollongong (Australia) mechanic Kevin Davis has done extensive testing of varying backpressure on a number of performance engines.....
...The tests came about because Kevin has developed a patented variable-flow exhaust that uses a butterfly within the exhaust pipe. He initially expected to use the system to cause some backpressure at low loads 'to help torque.'
However, he soon changed his mind when any increase in back pressure proved to decrease torque on a properly tuned engine. What increasing the backpressure does do is dramatically quiet the exhaust.
One of the engine dyno tests carried out by Kevin was on a modified 351-4V Cleveland V8. Following the extractors he fitted a huge exhaust that gave a measured zero backpressure. Torque peaked at 423 ft-lbs at 4700 rpm, with power a rousing 441 hp at 6300 rpm. He then dialed-in 1.5-psi (10.4 kpa) backpressure.
As you'll see later, very few exhausts are capable of delivering such a low backpressure on a road car.
Even with this small amount of backpressure, peak torque dropped by 4 per cent and peak power by 5 per cent. He then changed the exhaust to give 2.5-psi backpressure. Torque and power decreased again, both dropping by 7 per cent over having zero backpressure. These results were achieved on a large engine with a large overlap cam - one of the types some people suggest is 'supposed' to like backpressure.
If, in fact, power does increase with increased exhaust back pressure, it is most likely the air/fuel ratio and/or ignition timing that are no longer optimal for the altered state of engine tune.".....
Old Oct 8, 2011 | 10:13 PM
MIK3's Avatar
Reasons why I am definitely getting this:
1) Resonated
2) Aligns perfectly
3) 3" to match my 3" Cattman catback
If anyone is looking for a 2.5" non-resonated, I have one I'm trying to get rid of. Let me know!
Thank you, OP, for this find!
Old Oct 8, 2011 | 10:28 PM
Mr. Blue Sky's Avatar
definitely a great choice for those with 3" exhausts. I was looking at this exact test pipe a while back, but I don't have a 3" exhaust, so it wouldn't be worth it.
Old Oct 8, 2011 | 10:36 PM
Grimmrezx's Avatar
drool
Old Oct 9, 2011 | 01:08 PM
1) Resonated
2) Aligns perfectly
you will be very happy with it - I sure am.
Old Nov 27, 2013 | 08:15 AM
Simardfosgate3's Avatar
Will this 240 test pipe bolt up to a totally stock 03 maxima exhaust? Reason I ask is I am going to be adding headers and a catback in the future but would like to start adding some of the cheaper items first.
Old Feb 24, 2015 | 12:40 PM
Kevin Trout's Avatar
Hello, I just figured I'd resurrect this thread briefly instead of starting a new one. I'm looking to grab a 3" resonated test pipe from Ebay for my 2003 SE, however I'm having a little bit of trouble deciphering which one I need to get, as the original listings in this thread are very old and outdated, and no longer available.
Is there a specific year of 240 sx that I need to purchase for this? This one looks like it may work, but is a lot more expensive than what I was expecting to pay according to other thread results: http://www.ebay.com/itm/DME-3-STAINLESS-RESONATOR-CAT-DELETE-TEST-PIPE-89-94-240SX-S13-SILVIA-SR20DET/261094881372?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3Ddaa19d6d45cb4f2a8ddf612bf4bc7b18%26pid%3D100011%26rk%3D7%26rkt%3D10%26sd%3D370540055922
Old Feb 24, 2015 | 03:40 PM
NmexMAX's Avatar
dot dot dot ...
Is there a specific year of 240 sx that I need to purchase for this? This one looks like it may work, but is a lot more expensive than what I was expecting to pay according to other thread results: DME 3" Stainless Resonator Cat Delete Test Pipe 89 94 240sx s13 Silvia SR20DET | eBay
That's the one. And any 240 will work. I've had at least 2, and both fit perfectly.
I believe it's 89-98. http://www.enjukuracing.com/products...0sx-89-98.html
Old Feb 24, 2015 | 04:07 PM
Awesome, thanks a bunch. I have a warpspeed high flow cat that is coming apart on me, leading to some awful rattling sounds at lower rpms. I would purchase another high flow cat, but don't want to do so over again in a few years if it's too come apart again.
Old Feb 24, 2015 | 04:41 PM
george__'s Avatar
How can you stand test pipes? They WREEK
Old Feb 24, 2015 | 04:56 PM
Fakie J Farkerton's Avatar
that's just your car.
Old Feb 24, 2015 | 05:20 PM
D.Stillwell's Avatar
Idk. My hi-flow cat smelled pretty "good" there at the end of its life. Then again, it was used fastcat and prolly just old and abused.
Old Feb 24, 2015 | 06:00 PM
A HFC isn't a test pipe.
When cats go bad it smells like rotten eggs.
If your car is running right a TP shouldn't smell that bad.
When I had just my turndown on after the y I hardly smelled anything extra..just got a lot louder.
