Help..prob with suspension noise
I had tien h-tech springs and tokico illuminas installed and my front passanger and rear driver side makes noise when turning slowly...it sounds like a creaking then pop...was something installed incorrectly or maybe tightened too much?
It does sound like something was installed incorrectly. Did you get new bump stops, bushings, etc?
From what you are describing, sounds like the spring maybe twisting. Also, If I remember correctly, the top hat needs to be facing a particular direction.
Also, did they install the spring isolators on the bottom of the spring/perch? It's pretty much a thick rubber condom of sorts so the metal spring does not chafe against the spring perch.
I get the same sounds. I did replace the strut mounts and bump stops on all four corners with new oem parts. I also installed the top hats facing the correct direct and spring sleeves properly. I have narrowed it down to either using the crappy gsp brand axles because the passenger side axle from them is the same as the automatic (this means the axle is not long enough). I like to think that using an axle that is too short and turning the car fully (which is when the noises occur) is causing the axle to hyper-extend.
The other culprit could be the weak motor mounts. I have heard they cause a pop sound if faulty.
What axles are you running?
Do you have a 6 speed?
How do your mounts look?
I don't have the torque specs off hand, but when I installed all mine, I just snugged them down real good without a torque wrench. All was fine. I have the link to the factory service manuals in my signature if you wanted to download and take a look.
I don't know I'm still on factory suspension but twice I've heard a pop like that but only while making a left turn while accelerating.
Its like 2 pop sounds but my boots and stuff look fine. I don't know if its a worn bushing or what..........
Had vogtlands and KYB Gr2s installed a couple months ago and all was fine till about a month ago and I now have the sounds that the OP describes. Can't seem to figure out the cause. All I know that it annoys me to no end.
I have read recently that the sway bar end link can be the culprit. I get the same sound and I installed new ebay end links. The problem may be the fact that I used ebay end links istead of moog. I will attempt to rememdy this noise by first rebuilding the passenger side oem drive shaft because I still think this sound is mostly due to the slightly shorter than oem GSP axle. (As I stated earlier, the GSP 6 speed passenger axles are the same as the automatic units which is not the correct length.) If that doesn't fix the problem then new moog endlinks it is.
JakeOfAllTrades
Sep 30, 2015 03:16 PM
