Help!!!!! No Heat
Old Oct 30, 2011 | 09:49 AM
AngryHalfbreed72's Avatar
Help!!!!! No Heat
Recently I noticed no heat was blowing through
my vents when activated. Figuring the thermostat
was sticking, I purchased one and did a drain n fill
with new coolant. I still have no heat....I went on
and checked my floor boards to see if the heater
core may have took a dump on me and thats not
the case. Ive also noticed my radiator fans are
kicking on more than usual, keep in mind its been
pretty chilly here in Md. The radiator is full and Im
running out of conclusions......please help!
Signed "Mr Frozen" lol
Thanks!!!!!
Old Oct 30, 2011 | 10:09 AM
nelledge's Avatar
"I'm just sayin'..."
Do you have auto or manual climate control? Perhaps, the vent doors are stuck or the vent control is not functioning correctly? Also, you could have a blocked heater core. Check the temperature of your heater hoses. They should both be hot at operating temp.
Old Oct 30, 2011 | 11:04 AM
I have the manual climate control, all the vents
are working correctly and not stuck. Where is the
Heater Core located and is it easily accessable or
does the dashboard have to come out? Thanks
Old Oct 30, 2011 | 11:34 AM
nelledge's Avatar
I'm not talking about the interior 'vents'. I'm talking about the vent doors controlled by the lever on your climate control. The air mix door motor could be broken. You have to remove the instrument cluster to inspect it. Have you inspected it already?
What was the temperature on the outlet heater hose? Once you know that, you can take the next step. Otherwise, you may be spinning your wheels.
Old Oct 30, 2011 | 11:43 AM
chrome91's Avatar
your heater core could be clogged
Old Oct 30, 2011 | 11:44 AM
Oh my bad......I inspected the instrument cluster to see if anything was disconnected but as far as looking at the airmix door, no. To be honest I dont even know what it looks like. Can you give me sum insight please?
Old Oct 30, 2011 | 11:45 AM
nelledge's Avatar
Old Oct 30, 2011 | 11:51 AM
nelledge's Avatar
The air mix motor is behind the ashtray/pocket area behind the center console. You may be able to view it from the side footwell, but it's easy to take off the center console panel. Once off, you should be able to slide the lever back and forth on the control to see if the motor is functioning properly.
Old Oct 30, 2011 | 11:55 AM
Also I havent checked the hoses but I will shortly, at work at the moment. Lets say that if it is the heater core, wouldnt it be leaking if it was clogged or malfunctioning?
Old Oct 30, 2011 | 12:01 PM
Hey Nelledge Ill try that....Thanks alot!
Old Oct 30, 2011 | 12:09 PM
chrome91's Avatar
reading>me
Old Oct 30, 2011 | 12:18 PM
nelledge's Avatar
No.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
