Winter rim size
Old Dec 18, 2011 | 10:34 AM
Brl24's Avatar
Winter rim size
I know the pattern for our cars is 5 x 114, but my parents have a nice set of winters on steelies off a Subaru, which I believe has a pattern of 5x100. They are really nice, and freee so if I could make them fit that would amazing. Has anyone had experience with a similar situation?
Old Dec 18, 2011 | 10:43 AM
DennisMik's Avatar
The Maxima's rim is 6.5 inches wide, dictated by the width of the tire needed to support the weight of the car. Also the hole in the center has to be a certain size to fit over the axle. I don't know what that size is.
If the width of the Suaru rim is correct, try to put one on and see what happens. Ford rims also use the 5 x 114 bolt pattern and I think others have said they fit.
Old Dec 18, 2011 | 11:31 AM
Ghost_54's Avatar
You would need to pick up a set of spacer adapter and possible a set of hub center, the spacer adapters you would be able to change the bolt pattern. You would be able to change a 6 bolt pattern down to a 5 bolt pattern as well as change the spacing to match your needs mind you spacer adapters are not cheap and it would be cheaper just to buy the correct size rims in the first place, none the less it is another option for making the rims fit.
Old Dec 18, 2011 | 11:32 AM
RA030726's Avatar
I'm nutty for Nissans
5x114.3 is no where near 5x100.
Old Dec 18, 2011 | 11:39 AM
Rods03Max619's Avatar
Agreed my friend was trying to find adapters for a 4 to 5 lug and Damn they are some money....GL....
Old Dec 18, 2011 | 12:55 PM
DennisMik's Avatar
I missed the part about the Subaru bolt pattern being 5 x 100. Probably the cheapest he can do would be hit a junkyard for rims. Adaptors will probably cost more.
Old Dec 18, 2011 | 02:36 PM
TunerMaxima3000's Avatar
No dude not even close.
Just grab my winters off me , $200
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
