4th gen ECU in 5th gen
im sure ive research this before but say for exmaple somebody is doing a 5spd swap in the 5th gen, it is in fact possible to use a 4th gen 5spd ECU in the 5th gen correct??? just gotta get a reprogrammed key???
The connectors are completely different.
I'm willing to bet the the engine would run, as they are almost identical from a control standpoint, but you loose VIAS control and getting it to run code-free would be almost impossible. Too much emissions related mis-matching between the generations. The EVAP systems are very different.
I've thought about doing this too for the same reason. Mainly just for a 7500 rpm rev limit. Sure the emu can do it, but I was trying to avoid that annoying dip we get when extending the revs.
I talked to a guy from JWT a couple months ago about how hard it would be to do it and he said like Flava the connectors are different so there would be some tricky wiring to do but he made it sound do able, Nmex stated the 4th gen JWT ecu's run real lean but couldn't you just adjust it with a little a/f corrections via SAFC,VAFC, NEO etc ?
Ill be a test mule and supply everything needed if someone thinks they can do it, I already have a Neo to tune a/f's, They only thing that kind of sucks is 4th gens don't have NATS so i think if you swapped in the 4th gen ECU you would lose your factory security system. Ill even do a before and after dyno comparison.
Actual tuning that you can make changes , vs a pre set jwt ecu that you cant change?
Apples to Oranges to me
No need for the comparison imo, if you want tuning that works and will have less issues get a emu, pnp harness, wideband, there ya go. If you want to pioneer putting a 4th gen ecu in 5th gen its possible, but look for headaches, issues, obd2 compliance inspection issues, and a pre set tune. All the $$ time and effort to do the swap would be more then pnp emu IMO.
That's the real question what do YOU want?
understood.. see i dont really care for all that extra stuff with this car... a ECU + AFC and dyno time would be more than enough... i just want extended revs and tune thats all, dont really care for "maximum tuning capabilities"
I really don't see the benefits of using that ecu and a afc over a emu. $$ is not one
Coming from all the crazy ecu stuff i do, this would be top of the list!
But if ya need ecu connectors (4th n 5th gen) i got em.
Ya i see, but it wont be just the ecu? A AFC added in also?
Hahah, Trade all that in for a Haltech//////
ur not gonna do it lol
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
