relay wont come out
Old Jan 1, 2012 | 07:33 PM
vinny's Avatar
relay wont come out
hello all i am trying to pull the gray relay out under the steering colum in the back so i can reset my sunroof in my 2000 maxima ...why is it so dificult to come out i am pulling on it and it is stuck in there.....is there a clip holding it in thanks?
Old Jan 1, 2012 | 08:21 PM
BigLou55's Avatar
Why are you pulling a relay to reset your sunroof? With the sunroof closed and he car on press and hold(3-5 seconds) the switch that raises and lowers the sunroof. Press the end of the switch that closes the sunroof. This is the easiest way to reset it and it works I have had to reset it myself because my auto open stopped working, a quick reset and good as new. Good luck
Old Jan 2, 2012 | 06:48 AM
vinny's Avatar
biglou i have read many old posts on this and the reset that you explains works sometimes...however a old post that irish44 posted had showed that pulling the relay worked when everything else failed that is why i was inquiring about pulling out relay seems like it should not be that hard to get out
Old Jan 2, 2012 | 01:12 PM
BigLou55's Avatar
The relay may be held in by a screw or bolt, or jus in there really snug or jus needs to be twisted and pulled. sorry the button reset doesn't work for you.
AaronL
Nov 15, 2020 11:52 AM
zmcneely13
Sep 26, 2015 02:26 PM
Bluenissan
Sep 20, 2015 08:54 PM
BrandonCause
Sep 14, 2015 10:41 PM
