Steering Wheel Shimmy
Old Jan 5, 2012 | 08:44 PM
wyche89's Avatar
Hello. My steering wheel has developed a shimmy and I don't know where it's coming from. I did a search, but all the ones I saw dealt with higher speeds. My steering wheel moves back and forth at lower speeds primarily. Like less than 20mph. I made a video of it, and I'll try to get it uploaded shortly. Any idea what that movement is?
Old Jan 5, 2012 | 09:06 PM
nelledge's Avatar
"I'm just sayin'..."
Most likely your ITRs. If they've got high mileage on them, you might as well replace outers while you're in there.
Old Jan 6, 2012 | 06:24 AM
djfrestyl's Avatar
Suspension Yoda
Could also be a shifted steel belt inside the tire itself. Happened to me before. Tire had to be replaced.
I'd start by having the wheels balanced - then go with the above recommendation of tie rod ends, etc.
Old Jan 6, 2012 | 06:40 AM
ekafrawy's Avatar
When was the last time you had your tires balanced and an alignment done?
Old Jan 6, 2012 | 09:31 AM
wyche89's Avatar
I haven't had an alignment done, and my tires are kind of worn. I'll try having the wheels aligned and balanced when I get new tires. And if that doesn't work, I'll explore the tie rods. Thanks guys, I appreciate it.
HOKUSMAX
Nov 13, 2017 04:34 AM
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
