front left fog light
Old Jan 7, 2012 | 04:45 PM
michael454rs's Avatar
hey guys just got done switching out the bulbs on fog light because i tought the front left bulb was burn out. i swapped them out worked fine i move the car and my brother tells me the light is out again. i cheked the fuse in the cabin and it was only for the front right and its ok, i tought maybe i could be the realy under the hood but would both lights go out it the realy was bad. would appreciate any help. one more question is there a fuse for the front left fog. tried googling it but came up with nothing.
Old Jan 7, 2012 | 05:34 PM
TallTom's Avatar
Sounds like you got oil on the bulb which will burn it out quickly.
Old Jan 7, 2012 | 05:40 PM
I was extra carefull not to touch the bulb. I handled it by the base. The bulb i replaced was not burnt out or anything, going to open the fog again and take look to see whats going on. Can i rewire the fog to work with right one to turn on and off will it overload the fuse or cause problems
Old Jan 7, 2012 | 07:20 PM
DennisMik's Avatar
There is only one fuse to power both fog lamps. You need to check the wires that go to the lamp that does not work. If the lamp worked when you swapped the bulbs and then stopped working, You have a bad connection. Maybe it's the wires, maybe it's the socket.
Old Jan 7, 2012 | 09:23 PM
yeah gotta chek it out beacuse it was working fine when i installed the new bulb so i must be something with the connectin or the wire inside the housing will crak it open tommorow and chek it out
Old Jan 7, 2012 | 09:41 PM
CMax03's Avatar
Unplug the Foglight assemblies from chassis harness and turn them on the power to see if the fuse pops! If it does then there's a problem with the chassis harness.....Also check your foglamp assemblies with a VOM for a short @ the Foglight body!
Old Jan 7, 2012 | 10:08 PM
you mean unplug the fog light harnes from the harness of the car and turn the switch on to see if the fuse pop?
Old Jan 8, 2012 | 12:23 PM
found the problem, turn out that the plug where the fog connects to the stock harnes is not fully making contact. so i just zip tied them together a it works again for now until the the zip fail witch hopefully by then i have a permanent fix
Old Jan 8, 2012 | 03:26 PM
Zip dint all jad ditch the stock connection and used a pair of 9006 connection i had and its fully working.
Old Jan 8, 2012 | 03:38 PM
DennisMik's Avatar
That's great that you found the problem. Electrical problems can be tough to figure out.
Old Jan 8, 2012 | 03:46 PM
yeah, i was to give up, the i started moving the socket and saw it flickering. now to move on to the next project. bought an hid kit and umm im no real happy, going to keep it on for at leat a cuple of weeks until i can find a super white halogen bulb that i like somethign around 5000k.
Old Jan 8, 2012 | 04:16 PM
CMax03's Avatar
I'm glad you found your problem....
HOKUSMAX
Nov 13, 2017 04:34 AM
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 16, 2015 05:09 PM
