Lubricant for sway bar bushing
Old Jan 7, 2012 | 09:21 PM
eclipse98's Avatar
Bought a set of moog sway bar bushings and they didnt come wuth any type of grease i was wondering wat would be the best lubricant to use so i can avoid any sqeeking noise
Old Jan 7, 2012 | 09:30 PM
CMax03's Avatar
contact Energy Suspension or PolyBushings!
Here's what I use on my Mini-Mopar:
http://polybushings.com/pages/bushinglube.html
Old Jan 7, 2012 | 10:10 PM
02whitemaximase's Avatar
Lithium grease should suffice although the link provided above does specify a particular type of grease. I just installed my ES sway bar bushings today and it came with a small tube of tacky grease that looked a lot like white lithium. If you do plan on getting something local then just make sure you use thickest tackiest grease not spray crap.
Old Jan 7, 2012 | 10:16 PM
CMax03's Avatar
Originally Posted by 02whitemaximase
Lithium grease or bearing grease should suffice. I just installed my ES sway bar bushings today and it came with a small tube of tacky grease that looked a lot like white lithium. Just make sure you use thick grease not spray crap.
I've tried both and they don't last as long as the thick goowy grease! I've even tried synthetic grease and nothing has worked better than the polybushing formula grease!
Old Jan 7, 2012 | 10:20 PM
Sounds like he may as well do it right the first time and get that grease online. Nothing speaks higher than someone with personal experience.
Old Jan 7, 2012 | 10:30 PM
chunkysause7's Avatar
At Napa they have something called Sil-Glyde Silicone Lubricating, haven't tried it yet but it was suggested on another forum.
http://www.amazon.com/Sil-Glyde-Sili.../dp/B0054DWS1W
Old Jan 8, 2012 | 06:01 AM
cjandura's Avatar
pepboys carries the ES bushing grease in there performance section of the store.
Old Jan 8, 2012 | 08:58 AM
T_Behr904's Avatar
I've used graphite grease before. Works good.
Old Jan 8, 2012 | 09:29 AM
Rods03Max619's Avatar
Good to know, ordered from ES PARTS on Friday, Moog Sway Bar endlinks, ES sway bar bushings, motor mount inserts, and subframe bushings, I know some comes with it but just in case.... And from NMEX the ES LCA bushing and the RTA ones also.....
Old Jan 9, 2012 | 07:45 AM
CMax03's Avatar
That grease dries up!
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
