EGR BOP
Old Jan 12, 2012 | 02:26 PM
Hoffm2ma's Avatar
EGR BOP
Okay I have searched the org over and over, do they make a EGR BOP for the 2000 Maxima? Does NWP make one to fit?
The reason I am asking I have hotshot headers ready to install and there is no bung for the EGR. So I am wodering if I can delete it all together, I was told if I leave the temp sensor for the EGR than I will not throw a code. I was also told to JB weld a penny to the OEM plate to block the hole.
Please Help!
Old Jan 12, 2012 | 06:34 PM
essential1's Avatar
My axles cry for mercy...
Congrats on the hotshots.
The easiest solution is if you can find an 01 in the junk yard, they have a factory bop.
Old Jan 13, 2012 | 04:23 AM
Hoffm2ma's Avatar
Thanks man. If I can't find an 01 anywhere can I just order one?
Old Jan 13, 2012 | 06:57 AM
essential1's Avatar
You should be able too. I've never tried to order one myself though. If not, you can use the "plate" that attatches to the EGR guide tube in your stock setup. Cut off the tube and it will leave you with a hole. Just use something to plug this hole up. Similar concept to welding a coin to the manifold for the 4th gens. I dont remember if it's small enough for a coin though.
It's part # 14713 in this picture. That part bolts to the IM, just cut off that tube and seal the small hole somehow. The other option is to just make a piece out of scrap metal you might have lying around.
Old Jan 13, 2012 | 09:19 AM
Hoffm2ma's Avatar
Thanks man....I will see what I can come up with.
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
maxima297
Sep 24, 2015 10:31 AM
bumpypickle
Sep 19, 2015 01:07 AM
Maxboy23
Sep 4, 2015 06:04 PM
