Timing Ring Starting Problem(trans experts step in)
So i did a clutch/flywheel and transmission on my 01 SE about a month and a half ago. When it was done it fired up fine and was perfect. About three weeks ago i noticed the car was getting harder to start. And it seemed to get progressively worse and now it will crank/stop/crank and then start or it will just crank for 4 or 5 seconds and then start almost like the timing is off.
The starter was new so i picked up a CPS sensor because i had the same exact starting problem in my 4th gen and that's what it ended up being. I put the sensor in tonight and it did the same thing. BUT while cranking the car i had my friend looking at the timing ring inside the hole where the CPS goes into the trans and he said it's wobbling while the car is cranking.
It started perfect for three weeks and now it barely starts. My guess is the sensor can't get an accurate reading on the timing ring because it's not true but how ? The flywheel is a Fidanza and the clutch is ACT. I need to know if Anyone else has run into something like this before, obviously the trans has to come out again and im curious if we missed something like a spacer or washers or something.
The car has a slight vibration under acceleration but i thought it was a bad pass axle but maybe it's related to the timing ring spinning out of alignment. The car runs drives and shifts beautifully. When we moved the sensor toward the pass side it started better so i guess the ring would have to be moved to the right a little. Any help would be greatly appreciated.
I'm far from an expert, but I'd install a dial indicator in the timing hole, and bar the engine over by hand with the clutch pedal depressed (disengaged). Easy way to check FW runout without disassembly, that will at least tell you if the FW is true.
Possible the ring gear warped after things warmed/cooled a number of times, as they're just a press on unit and you're dealing with an Aluminum FW.
^ they should at least refund the cost of the FW if not partial labour costs, supposing you can get someone you know to print out a receipt that looks reasonably real with a true Business number.
All things said though, I'll never buy a LW flywheel, I've researched the crap out of them and they really seem to be more of a placebo effect anyways on most cars. Not to mention added chatter, lost reliability, etc, etc. All that said, stock FW's are stupid expensive, so I can't fault anyone for going the cheaper route, I'd probably do the same if stuck in that situation. But I'd never throw a good stock FW away for a cheap lightweight one.
I'm so glad I don't have to do a clutch on a FWD 3.5
Hat's off to you sir.
My friend is having trouble w/ his Fiddy FW because of the design, the bolts broke causing the starter ring to spin.
I've stripped out the bolts bolting the PP properly easily
So what I'm saying is, it probably is not out of this realm that the trigger ring got bent somehow during operation or just wore out.
Im not sure if it's the ring gear thats not true or the flywheel causing the ring gear to wobble. All i know is there is zero chatter when engaging or dis engaging the clutch which leads me to belive it's the gear and not the F/W. But it almost looks as though the ring gear needs to be moved over more to the driver side because when you push the CPS to the left and try to start it starts better unless its just the ring being un true.
I still need to see if it's the flywheel thats not true thats throwing the ring off or if its just the ring. I re used the old ring and never had a problem with the car starting that's why im kind of pointing to the flywheel. But then again theres no chatter ?? Only a slight vibration under acceleration which i thought was my pass axle.
Problem solved, I ran a ground from the negative on the battery to the starter bolt and it fired right up, Thanks goes to this thread. Another starting problem-replaced just about everything
my friend and i recently swapped out an engine on a 5.5 gen where the owner had recently installed a LW flywheel. We found all of the bolts that secure the flywheel to the engine to be loose. The flywheel itself wobled on the crank. The flywheel go damaged pretty bad that it ended up needing replacement. I hope this is not the same issue as ours but from the looks of it, it might be the same.
The problem I believe is the bolts have a hard time staying in place. Just like when mounting aluminum wheels, it is recommended to re-torque everything within 25 miles or so, i believe the bolts to the flywheel just don't torque properly. Did you use thread lock? If you can see the flywheel wobble through the cps hole, I would strongly suggest not to run the car and drop the tranny asap to prevent further damage.
I see what both of you guys are saying and i know the factory allows some run out but not sure what the tolerances are, But the F/W bolts could have backed out i guess. I tightened them to factory specs and followed everything to the T.
I don't know offhand I'll check the FSM. Offhand though, I can definitely say that whatever the specs are, you shouldn't be able to see it by eye, and especially not through a timing hole. Something is wrong.
vingodine
45
May 21, 2016 12:46 PM
