Spark Plugs?
Spark Plugs?
ok well iv seen that the recommended plug for mt 5.5 is the ngk iridiums but my question is my car has intake header exhaust vias block off and plenum spacers so should i still run the same plug ngks?
I have E3 spark plugs installed right now. They currently have around 30k on them, and so far so good. Figured if they didn't hold up i'd just change them out since changing the spark plugs on a 3.0 De-K isn't all that involved since the UIM doesn't need to be removed to get to the rear plugs.
then
VQ30DE-K FTW!!!
I love the fact that it only takes me a few minutes and some elbow grease to tune up my car
Oh FWIW, i sprayed a little bit of carb cleaner into the spark plug holes while i had the plugs out, i intended on spraying SeaFoam into the holes instead, but after i removed my plugs and was ready to spray i found out i had no more SeaFoam left ...so i took a can of carb clean and shot maybe a few ounces into the spark plug holes before putting in the spark plugs, and maybe it's placebo but it feels snappier in throttle response.
The whole reason why i replaced the plugs was i noticed my MPG was going down , and it started to feel sluggish.
Lately i have noticed it feels better after i did the tuneup/carb cleaner spray ( while i cannot be held responsible if you screw anything up, i also do not recommend pooling up any kind of liquid into the spark plug hole , a quick spray of a carbon cleaning fluid should suffice ) .
I would have rather have used Sea Foam in the combustion chamber, but carb cleaner sufficed .
good luck
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
