Taking out the rear seat
Old Jan 2, 2002 | 06:16 PM
Greg's2kGLE's Avatar
How do you take out the rear seat(s)? Does anyone know how much it weighs? If I go to the track, I guess this is the only seat I can remove since I have front side impact air bags, and I heard that if you disconnect the connection for it, it throws an error code to the ECU. Thanks!
Old Jan 2, 2002 | 07:05 PM
Tanman's Avatar
Re: Taking out the rear seat
The bottom bench section of the rear seats comes out easily. If you lift the front edge on the rear seat, there's a little pull-ring on the left and on the right. Pull a ring and lift up on the seat. Have to do this on each side. Now the back portion of the seats, that's a little trickier and requires unbolting stuff, which I haven't done.
Old Jan 2, 2002 | 07:09 PM
BigDogJonx's Avatar
Weight wise, it is damn near nothing, it is nothing but FOAM and some springs.
I would say 5-10lbs MAX
Old Jan 2, 2002 | 07:16 PM
Tanman's Avatar
The bottom part, true.
Old Jan 3, 2002 | 06:20 AM
BioMaxDDS's Avatar
yup, i think with the weight of the rear seats, its not worth the time to do it
Old Jan 3, 2002 | 07:24 AM
TimW's Avatar
The silent but deadly Moderator
heh..
yeah that foam thing is like anti matter. lightest part on the car. You should just fill the car with helium before heading to the track
Old Jan 3, 2002 | 08:04 AM
swallac2
Don't eat for 3 days before going to the track. It will probably be easier and a bigger gain then the seats!!!
Old Jan 3, 2002 | 08:10 AM
NmexMAX's Avatar
dot dot dot ...
Re: Re: Taking out the rear seat
Try 2 days cuz three, you may not be able to press down the pedal as hard is as needed for a good E.T.
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
