problem after nwp spacers install
Old Feb 26, 2012 | 11:29 AM
02max245's Avatar
Well I installed the NWP spacer with the help of a friend he ended up cracking the upper intake manifold near the left side stud and now the car wont idle and there is no pressure on the break peddle. I was not able to perform the relearn procedures correctly. do you think a piece of the intake manifold dropped into the LIM or what. Need responses ASAP.
Old Feb 26, 2012 | 11:31 AM
02max245's Avatar
or do you think its because i have an intake leak from the crack. And how drive able is my maxima in this condition.
Old Feb 26, 2012 | 11:39 AM
You definitely have a vacuum leak which is causing all of your problems. You car doesn't seem to drive able.
Try getting it welded back together or try some epoxy.
Old Feb 26, 2012 | 12:11 PM
03VQMAX's Avatar
Very important to torque fasteners down properly, that same thing happened to a member here in SoFlo..
Old Feb 26, 2012 | 01:14 PM
02max245's Avatar
Pulled a few codes p0300 in particular which is bank 2. The only thing iam worried about is the loose peices attached to the mani falling into the LIM.
Old Feb 26, 2012 | 01:45 PM
Ghost_54's Avatar
In your original post you mentioned the IM as being cracked, which wouldn't really create a piece to fall into a cylinder (If a piece did fall I am pretty sure you would hear the noise for something being in there) ... as stated above you most definately would have a vaccum leak, which needs to be addressed. The P0300 is for a multi mis fire which could be from either bank of plugs ... did you change any plugs, valve covers? or just install the spacers?
Old Feb 26, 2012 | 01:49 PM
Crusher103's Avatar
how do you crack the IM?
your gonna need a new im or find a way to seal up the cracked one. Vacuum leaks are pretty much the cause of a lot of rough running situations.
Old Feb 26, 2012 | 02:15 PM
T_Behr904's Avatar
I'm sure the cracked IM can be patched up with some JB Weld, since it's made from aluminum. It might not look pretty, but it will get the job done until you can find a replacement.
Old Feb 26, 2012 | 05:08 PM
Xpcgamer's Avatar
I wonder who that was???
Dude it snapped I went "Oh Snap!" and starting sending messages to see who had a spare. I ended up driving an hour to buy a replacement.
Don't bother doing anything else till you but another one and then torque it correctly.
Then you can do all the relearn stuff. No easy way out.
Old Feb 26, 2012 | 05:37 PM
02max245's Avatar
Bought a spare which will being going in tonight. The cracked one will get welded and put aside for ssim. On another note does anyone else have trouble reseting their ecu? I ve tried it on 3 seperate occasions and i still can get it.
Old Feb 26, 2012 | 05:39 PM
02max245's Avatar
A buddy of mine was helping me out with the spacers,plugs, valve covers, and bop. Hes an audi guy i expected better... He was torquing down the mani and the thing just buckled, i was like WTF. then i saw the damage and WTF indeed
Old Feb 26, 2012 | 05:44 PM
T_Behr904's Avatar
did you try disconnecting your battery?
Old Feb 26, 2012 | 06:05 PM
Xpcgamer's Avatar
I still to this day have not done the Air volume relearn thing. I CANNOT get it no matter what I do. I am just glad my car is running right even after that not getting done.
Old Feb 26, 2012 | 06:14 PM
02max245's Avatar
thats what i mean the air volume relearn
Old Feb 26, 2012 | 06:37 PM
Rods03Max619's Avatar
Hope you figure it out...
Old Feb 26, 2012 | 08:48 PM
nelledge's Avatar
"I'm just sayin'..."
...anyone else have trouble reseting their ecu? I ve tried it on 3 seperate occasions and i still can get it.
I still to this day have not done the Air volume relearn thing. I CANNOT get it no matter what I do...
Weird. It has worked the first time for me. Twice. However, it wasn't necessary for my NWP spacer install.
This is the one that doesn't work for me. I've had it disconnected for over 8 hours and nothing. I got impatient and used the pedal dance. Boom. Reset.
Old Feb 27, 2012 | 09:30 AM
02max245's Avatar
Ok finished the intake swap and everything seems fine. The extra power is very noticable. The only thing thats still going on is i have no pressure in my brake lines. Fluid levels are fine. what could have happened to cuz this problem?
Old Feb 27, 2012 | 09:46 AM
TheIntrepidMontti's Avatar
^ Sounds like air in the lines
Try bleading them, if that does nothing you may have damaged one of the lines running into the engine bay from taking off the manifold
It shouldn't have changed if you haven't touched the breaks though.
Old Feb 27, 2012 | 09:49 AM
NYCBL00D's Avatar
just jb weld it and paint your uim. $10 fix
Cotozic
Jun 28, 2017 08:01 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
incubusjohnny
Nov 3, 2015 05:18 PM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
