People with obx headers
Old Mar 3, 2012 | 09:28 AM
dnice02's Avatar
What are you guys doing for the "Bee's in a can" sound ,and the banging under hard acceleration. It's really starting to annoy me.
Old Mar 3, 2012 | 09:34 AM
pimpin02max's Avatar
I have OBX headers and don't have either of those problems, and I didn't have to do anything...
Old Mar 3, 2012 | 09:59 AM
Old Mar 3, 2012 | 10:07 AM
dnice02's Avatar
Its a rattling sound in between 21-2400 rpm. Also when i first start the car i hear it for a while. The banging happens when i loose traction. I think its hitting that cross bar, where the y pipe connects to the cat back.
Old Mar 3, 2012 | 10:20 AM
MizzMaxine's Avatar
heat shield
Old Mar 3, 2012 | 11:16 AM
2damax's Avatar
^What heat shield?
Old Mar 3, 2012 | 03:16 PM
luvlexus101's Avatar
Sounds odd, trade for my exhaust?
Old Mar 3, 2012 | 03:24 PM
clintb3astwood's Avatar
I had that annoying a$$ issue, checked it out at a shop they said it was the y pipe. Turned out to be total Bull, it was actually a loose O2 sensor not screwed in properly. same issue around 2k,2,500 rpms i would hear it. Took it to another shop, put it on a lift and had it tighten and no more bees in a can lol
Old Mar 3, 2012 | 04:39 PM
dnice02's Avatar
I'll check into that. I thought i read where a few others said it was in the flex. IDk
Old Mar 3, 2012 | 07:02 PM
ranmas2004's Avatar
I was thinking heat shoeld too. I can hear it under the car at times, doesnt annoy me enough to do anything about it though.
Old Mar 3, 2012 | 07:06 PM
2damax's Avatar
Seriously, I do not know what heat shield you guys are talking. Someone educate me please.
I like the "hitting the crossbar" theory. Check for play in the exhaust or any marks from banging.
Old Mar 3, 2012 | 07:11 PM
AznRyan's Avatar
Maybe that heat shield?--v
Old Mar 3, 2012 | 07:12 PM
AznRyan's Avatar
Different brand, but heat shield would still look the same :P
Old Mar 3, 2012 | 07:22 PM
2damax's Avatar
Thank you!! Idk why I thought headers would eliminate that.
Old Mar 3, 2012 | 08:13 PM
schmellyfart's Avatar
No.
Sounds like the y pipe is hitting the crossmember. If you reused the stock exhaust hanger near the cat, then heatshields shouldn't to be your issue. Jack the car up and and see whats what.
Old Mar 3, 2012 | 08:15 PM
02whitemaximase's Avatar
The obx y pipe has no heat shield. I don't have the bees in can sound but do have the banging only under hard acceleration with no traction. I agree that it is hitting the subframe.
Old Mar 3, 2012 | 09:52 PM
Rods03Max619's Avatar
OBX headers....
Old Mar 4, 2012 | 06:12 AM
Xpcgamer's Avatar
I was wondering how long it was going to take for somebody to put 2 and 2 together. Why are people showing pics of a stock y pipe when he said he had OBX headers?
Old Mar 4, 2012 | 06:14 AM
95VQ30's Avatar
don't get that but I do get a metallic whistle under hard acceleration
Old Mar 4, 2012 | 06:39 AM
2damax's Avatar
Ok so I may have been correct. Nice. OP, do as someone snd myself already said. Jack up the car and look around.
Old Mar 4, 2012 | 09:55 AM
dnice02's Avatar
As soon as the rain stops i'll get back under there.I was thinking about removing that cross bar. And as said above there's no heat shield.
Old Mar 17, 2012 | 08:10 AM
dnice02's Avatar
Found the problem well sort of. three of my o2 sensors were lose is what was causing the horrible sound at start up. I also added an extra hanger to help with the banging under hard acceleration.
Old Mar 17, 2012 | 08:42 AM
NICE...
Old Mar 17, 2012 | 01:07 PM
Seee! What did i tell you bro? Loose O2 sensor was making the sound
Old Mar 28, 2012 | 01:16 PM
vq_ryder's Avatar
Seems like you found your problem, When i installed my obx i can feel the max vibrate through out the frame under hard acceleration, solution: i grinded off 1/4 off from the crossmemeber contacting with the flex. I also had that bees in a can ish like noise. solution: the obx had pushed my Megan back a little and having my the flanges vibrate against the heat shield so I swaped out the muffler hanger with a shorter one to pull it more to the opposite direction. Other than that im pleased with the sounds and proformance.
No all i have to do is solve the CEL for my secondaries . o2-simulators.com are on back orders. DAMIT! eating tons of gas at this kind of time $4.15 a gallon.
Old Mar 28, 2012 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
PUR bushings, ES bushings on the sub-frame and an ETL should stabilize the engine a bit better under hard acceleration.
vqryder, how are your secondaries set-up right now?
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
BobTX10
Oct 7, 2015 08:43 AM
Socalstillen
Sep 26, 2015 12:01 PM
