Advancing Question
Old Mar 3, 2012 | 06:56 PM
kurt1's Avatar
Advancing Question
Hay all. I own a aus spec Nissan maxima-teana vq35. I been looking at advancing timing threads. My car is a 2005 model in Australia they say this is a 6th generation. From my research no more the 17 degrees timing. And a dealer can only do this so I talked to my Nissan dealer and they said NO. But I rather
Buy my own scanning tool anyways to check codes etc. So Wat scanning tool should I buy to do this and what price etc? Cheers Kurt.
Old Mar 3, 2012 | 07:02 PM
T_Behr904's Avatar
As far as I know it has to be done with a Nissan scanner, unless there's another way that someone wants to chime in on.
Also, from research i've done in the past, it only adds a couple of horsepower at best.
Old Mar 3, 2012 | 07:13 PM
ranmas2004's Avatar
Its done with a progran called Cipher from uprev. I paid about $200 for the program. You can advance timing to 17 degrees.
As far as power. You have to look at area under the curve. Before my advance I was at 259hp and 251 ft-lbs.....after the 17 degree advance I dynoed again....259hp and 255ft-lbs. Dont look like much,but if you go to dyno section and look at the dyno you will see torque increased all rpm range and hp came on earlier in all rpms....also smoothed out a little hump I had in the graph.....the way the car drove was a BIG difference....thing has tons of torque down low and takes off like a rocket after 4k rpms.......so it is REALLY worth doing!!!!
Old Mar 3, 2012 | 07:29 PM
kurt1's Avatar
Cheers mate. Can u give me a link to this product? Aswell how does this program work it must have a adaptor cord running from the car to a computar or
Something? Wat models does this fit Aswell? Cheers kurt
Old Mar 3, 2012 | 07:30 PM
TunerMaxima3000's Avatar
I noticed a difference right away in responsiveness too.
As mentioned above there are a couple ways to do it. I had mine done by Knight_yyz at one of the meets we had so I can't help you much. He did it without CONSULT II though.
Old Mar 3, 2012 | 08:15 PM
T_Behr904's Avatar
I forget you 3.5 guys have E-throttle, so I can understand doing it for better throttle response.
A friend of mine that had a 5.5 Max did the timing advance, and he did like the added response. He did before and after dyno's, and it was inconclusive since the Florida heat is a horsepower killer, and it really didn't show up on a dyno. Those things do have a margin of error... sometimes in your favor, and sometimes not.
Personally, if I had a 5.5, I would do it solely for the purpose of added throttle response.
Old Mar 3, 2012 | 08:52 PM
6spd_Hayes's Avatar
See the thread below:
http://forums.maxima.org/all-motor/4...ive-proof.html
Old Mar 3, 2012 | 08:56 PM
T_Behr904's Avatar
Originally Posted by 6spd_Hayes
I remember coming across that thread a while back. I'm surprised you only got a couple of hp/tq out of it considering your mod list.
Old Mar 3, 2012 | 09:47 PM
Rods03Max619's Avatar
I think the Bullydog does it for some years of 6th gens cause a guy in Cali used one for a couple of 6th gens locally, it says some Maxima years for the 6th but none for the 5th...
Old Mar 4, 2012 | 03:14 AM
kurt1's Avatar
http://www.bullydogperformancechip.c...45-2005&clev=0. Is this the product your talking about?
Old Mar 4, 2012 | 12:45 PM
Reizy's Avatar
http://www.uprev.com/products.php#product_cipher
Comes with proprietary OBDII to USB cable. You use it with their software.
pears
Sep 18, 2015 05:25 AM
14GmMax
Sep 17, 2015 09:08 PM
Serotta33
Sep 17, 2015 12:14 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
