Change LED color on A/C controls??
Old Mar 4, 2012 | 07:50 AM
ranmas2004's Avatar
I just did that LED swap with the blue lights in the cluster and it looks great. I hate that ugly green LED in the clock and the A/C controls display though (not worried about BOSE garbage because that is coming out soon). Is there a way to make A/C controls and clock LED displays blue? And what about lights on the window and lock controls on the doors....can those be changed to blue as well?? I know TunerMax is the master of lights....hope you respond.
Old Mar 4, 2012 | 07:57 AM
03VQMAX's Avatar
Yes, Yes, Yes and Yes.... Answers all questions?
Old Mar 4, 2012 | 08:04 AM
MizzMaxine's Avatar
there are countless threads on this topic
Old Mar 4, 2012 | 08:12 AM
cjandura's Avatar
Man hit up the tunermax poll thread i did a complete writeup with tuner on how to do it
Old Mar 4, 2012 | 08:18 AM
ranmas2004's Avatar
didnt even see that.......my fault.
Old Mar 4, 2012 | 08:21 AM
Galactica's Avatar
There's a guy in the 5th gen classifieds selling a complete master switch with the blue LED's all soldered on already for 45 bucks. I'd get that and just swap yours out!
Old Mar 4, 2012 | 09:42 AM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
If you are looking to change the LCD display color you are going to have to use pink tint to whiten the display and light blue tint to make it blue. You can find both on ebay from a seller called metrorestyling.
cjandura's Avatar
If you have any issues just hit one of us up its easy to do.
Old Mar 4, 2012 | 09:52 AM
TunerMaxima3000's Avatar
This, for changing the LCD colour. However, you DON'T need to install two different colours, you simply need the correct colour. IIRC, to acheive blue, you need purple.
To get white, you can use a light Red. Pink draws some blue hue out, so if you want pure white you sacrifice some output and use light red.
PM Knight_yyz, he knows exactlywhat colour to use to acheive blue, as he's done blue in his car and tested numerous shades to acheive it.
As for the other stuff you've already been directedto the how tos that are out and there's more around. PM or post back if you run into problems.
Old Mar 4, 2012 | 01:43 PM
02whitemaximase's Avatar
Tinting the lcd displays works perfectly on the ac controls but just so you know, doing it on the clock will make it nearly impossible to see during the day. I done care because my radio has a clock and the stock clock looks much better at night. Don't forget to snip the illumination wire.
Old Mar 4, 2012 | 01:50 PM
Yeah you HAVE to cut that wire or you won't see the clock at all when the lights are on. Good point.
Old Mar 4, 2012 | 01:51 PM
Amerikaner83's Avatar
when you do the climate control LEDs, be sure and do the 360* view angle LEDs to eliminate the hotspots in the backlights.
If you change the indicator LEDs from stock to blue, they will be HELLA bright, so sand down the LEDs and apply white-out to them to get them to not be blinding. BUt if you have the auto climate control, you don't have the indicator LEDs, that's just for the manual CC I believe
Old Mar 4, 2012 | 05:16 PM
Shinjiduo's Avatar
Touche but I like the control using pink and light blue give me. Purple is simpler and if you get it just right minimizes light output degradation. However if done worng is an epic fail.
Old Mar 4, 2012 | 05:32 PM
^No doubt. If you don't have a sample placcarrd/folder of translucent paper to test different shades, your way is the simplist and will assure the output desired (in colour. at least)
vingodine
45
May 21, 2016 12:46 PM
dr3am
25
Oct 22, 2015 08:53 PM
Max8
Aug 20, 2015 07:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
