need auto trans for my 03 or has anyone ever rebuilt one any tips
Old Mar 5, 2012 | 06:15 PM
86ttop's Avatar
so ive read alot of post about thies cars and ive turned to love this car ive been enjoying this car than the trans starts delaying between gears
so i talked to the dealer and they said it sounds like i need to flush out the trans that the valve body was cloged up so i pulled the valve body out and pulled it apart and cleaned it and put in newfluid much better but it still gits stuk in 4th and now it kinda feels like its sliping into 3 but at the same time it down shifts nice and solid into 3 so im out of ideas any
help for me
Old Mar 5, 2012 | 06:28 PM
2damax's Avatar
dudenoonecanunderstandawordyouaretryingtosay. Dontlistentohalfofwhatadealershiptellsyou. Youpulledoutthevalvebodyandcleanedit? Imeanslippingcanjusthappentoatransmissionasitisgoi ngoutandtheonlywaytofixitistorebuildorreplace.Howm anymilesareonithowlonghaveyouowneditandwhattrannyf luiddidyousue.
Old Mar 5, 2012 | 06:33 PM
Rods03Max619's Avatar
Are you manually shifting a Auto, or just hauling @$$ to get up in 4th gear since it is a 4AT....
Old Mar 5, 2012 | 08:48 PM
LongoTE's Avatar
maybe i can decipher what he is asking because i have a feeling my tranny might also need a fluid change.
When he is traveling a certain speed with his transmission in 4th gear, he takes his foot off the gas and it feels like the transmission downshifts to third or is engine braking. And then when he re-applies a little more gas , it feels like the transmission "kicks" up into the next gear and feels like its being powered/gliding in neutral (like an AT).
If this is your question then i am in the same boat. If not, can anyone confirm/deny this is normal behavior for me I only started noticing it recently and cant imagine the car is supposed to feel this jerky, unless its just my "footwork".
Old Mar 5, 2012 | 08:53 PM
artilarygoboom's Avatar
Should of bought a 6 speed to begin with, then you wouldnt have that problem lol.
Old Mar 6, 2012 | 01:55 PM
86ttop's Avatar
Well the problem I had was a delay inbetween shifts in every gear like it started to go for the next gear than just stops for a second than would go into the next gear like normal but after I cleaned the valve body and put new fluid (castrol Nissan spec.) It shifts great but still is a little slugish shifting up into 3 but when I gas it and it down shifts from 4 to 3 it is perfict and it only has 115k on it and I would love a 6speed but this was a $500 car that has been wrecked 3 times but its still nice as a daily driver and has lasted me 1year so far
Old Mar 6, 2012 | 01:58 PM
86ttop's Avatar
And I've manually shifted it my self and let it do the work doesn't help
Old Mar 6, 2012 | 03:14 PM
How is the motor mounts I know I had a hiccup, cause they were shot and then installed those ES MM and now keeps on pulling way better.....
Old Mar 6, 2012 | 03:55 PM
foodmanry's Avatar
Da Roller Coaster!
I know yours is an 03, but this may apply. Possibly TCM or solenoids.
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
Old Mar 6, 2012 | 07:25 PM
86ttop's Avatar
That def sounds like my problem but from my understanding so far and I could be wrong is that the check trans light should come on if they are bad but they may be cloged so I think ill drop the pan again
Old Mar 7, 2012 | 09:25 AM
foodmanry's Avatar
Da Roller Coaster!
Not all the time...I had slipping from 1-2 within my first 20K miles on the car after buying new. It was all covered under warranty at that time, but the trans light never lit.
If you are going to drop the pan, you might as well get new solenoids and change them out.
Old Mar 7, 2012 | 01:12 PM
86ttop's Avatar
I would but I'm broke right now and it was full of sludge b4 and I didn't think to clean them out so I'm trying to be cheap for now
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
