Question
Old Mar 6, 2012 | 09:55 PM
grip1968's Avatar
Question
Were is the oil cooler coolant pipe on a 2000 max, Im seeing a coolant leak on the passenger side by the oil pan, I took it to a shop around my way & this mechanic said I need to have my water pump replace. I heard these pumps last along time. I got 257,000 miles on my max.
Old Mar 6, 2012 | 10:13 PM
vq_ryder's Avatar
I think 257K is pretty long . Depends what you definition of long time is. Long time miles or long time years?
Old Mar 7, 2012 | 01:14 AM
grip1968's Avatar
Miles....
Old Mar 7, 2012 | 09:11 AM
DennisMik's Avatar
Your mechanic is probably correct. There is no cooler for the oil on the 2000.
Old Mar 7, 2012 | 09:17 AM
foodmanry's Avatar
Da Roller Coaster!
It could be the oil pressure sensor. See my thread on my oil leaks for my 2k. One of them is on oil pan coming from the oil pressure sensor. Pics are in my thread.
http://forums.maxima.org/5th-generat...d-insight.html
Old Mar 7, 2012 | 09:49 AM
DennisMik's Avatar
The op has a coolant leak, not an oil leak. I had to read the post several times before I got that.
Old Mar 7, 2012 | 10:39 AM
foodmanry's Avatar
Da Roller Coaster!
Woops! You are right. Sounds like the water pump o-ring.
Old Mar 7, 2012 | 10:09 PM
grip1968's Avatar
Ok I thought the 2000 maxima came with the oil coolant tube, anyway my mechanic said since he have to changed the water pump, he mines well do the timimg chain too, my issue is I never had a problem with my timimg or the timimg chain, Should I just let him changed the water pump and leave the timimg chain alone??? or just do everything at once.
Old Mar 8, 2012 | 09:37 AM
DennisMik's Avatar
The timing chain tensioners probably have lots of wear on them. Usually the chain is still OK. But he doesn't have to mess with the chain or tensioners just to do the water pump. Ask him what the prices are for just the water pump and for the water pump and chain.
Old Mar 8, 2012 | 01:35 PM
2damax's Avatar
How much extea is he charging to do the chain? From my understanding, thats a lot more money! I would not bother with the chain.
Old Mar 8, 2012 | 09:03 PM
grip1968's Avatar
He wants 360.00 to do the water pump, I havnt asked about the water pump & timing chain.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
