Car in fail safe mode
I have an 02 max with 110k on the clock and having some trouble. When I jump on it hard it goes in to fail safe mode. It doesnt really respond to gas and just idles till you can pull over and let it sit for a min then restart with no issues. I have a couple codes vias solenoid problem and a throttle position code. Everytime you get in it hard it just jumps to this mode. What could this be or how do I find out?
I would start with troubleshooting the two codes you have. I'm guessing that TPS code may be causing the problem. However, it's just that without further information. A guess. Do you have a decent DMM and know where to access the FSM? It gives good, detailed instructions on how to troubleshoot a myriad of components.
came in here to post this
sounds like your TPS is sending the incorrect signal to the ECU.
But never assume , grab the FSM and a decent multi meter and test the components in question
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
scarletsosa
Aug 17, 2015 09:09 PM
yat70458
Aug 3, 2015 01:16 PM
