o2 SIMULATORS Help. Please?
Old Apr 2, 2012 | 09:33 PM
vq_ryder's Avatar
2002 Nissan Maxima 6sp
Ill cut it short, I bought two heated o2 simulators from amazon because o2simulator.com is back logging until further notice, could be weeks to months. Installation was pretty strait forward. Red=ACC/PWR |Yellow=Signal/Black o2 wire |Green=Ground/Grey and two whites are Heaters.
http://www.amazon.com/Oxygen-Sensor-...3426548&sr=8-2
Now I was able to clear one code p0158. However another code has arised. P0057. According to nissanhelp.com the problem lies in the wiring, low voltage, wires shorted, bad connection or bad o2 this code is ONLY concerning with the heaters other wise its sending out the correct voltage to the ECM to clear the P0158 witch is Circuit high voltage. What did I do? I redid the both wiring, re-crimped, heat shrinked, and taped both secondaries and reset the ecu via the whole key and pedal method but no luck. Luckly the ECU is only throwing me one code at a time. Im running OBX headers/y-pipe and spark plug non-fouler didnt work for me.
I have yet to re-attach the o2s, plug it in and try tapping it into the o2 sensor wires them selves as a last resort, and as iv seen with other o2 simulator installs here on the org. These simulators are suppose to be full stand alone without tapping into the o2 according to the instructions/descriptions. Has any body come across a situation like this? and did you solve it? How? I also contacted the seller, and still waiting on his response.
Old Apr 2, 2012 | 09:55 PM
JonBlz's Avatar
a.k.a. STuNtMAN
the white wires you have to cut them from the plug on the blue and green one and the wire running from the harness you connect them with the o2 sim white wires
here's where i got my sim with instructions and everything just in case
http://www.3sx.com/store/comersus_vi...?idProduct=769
here's the write up make sure its exactly like this
http://forums.maxima.org/5th-generat...tallation.html
Old Apr 2, 2012 | 10:53 PM
vq_ryder's Avatar
I dont get what you're trying to say can u rephrase it? lol sorry, but i will try the way puppetmaster has it on his install. thanks
Old Apr 2, 2012 | 11:01 PM
JonBlz's Avatar
a.k.a. STuNtMAN
^^read what puppetmaster does with the white wires and you should be perfectly fine
Old Apr 3, 2012 | 08:16 AM
Rods03Max619's Avatar
**** I still got to order mine from there, I barely just got my primaries extended, but Good Luck man....
Taino14
Sep 24, 2015 02:51 PM
hozay99
Sep 19, 2015 10:20 PM
