Bose Sub Woofer Not Working
Old Apr 4, 2012 | 09:51 PM
beezieweezie's Avatar
Just bought a 02 gle with 73k on it and just realized that the bose subwoofer doesn't work at all. I checked in the trunk and it's all plugged in. I seen the little amp next to it but didn't see a fuse. Do I have to take it out to change the fuse? Anyone have any ideas? Thanks.
Old Apr 5, 2012 | 05:01 AM
LongoTE's Avatar
Try tapping on the subwoofer or subwoofer amp and see if it kicks on for a little bit. The majority of people's cars have subwoofer issues and it can attributed to a faulty relay located in the sub amp for the 5.5 gens. On the 2000 there is a separate board that you can simply unplug and bypass.
I recommend buying a new relay and getting it soldered in place of the old one in the subwoofer amp. Someone here sells the replacement relay for $15 but i cant remember his username.
here is the thread about fixing the issue
http://forums.maxima.org/5th-generat...01-maxima.html
Old Apr 5, 2012 | 05:07 AM
djfrestyl's Avatar
Suspension Yoda
Couldn't have said it better myself.
Old Apr 5, 2012 | 07:17 AM
Galactica's Avatar
There is also a little more ghetto fix that I did myself after doing some research here that works very well. It involves building basically a paper washer and using the frame of the amp to push on said relay holding it on the board better. It's worked perfect so far and doesn't take much time.
Old Apr 6, 2012 | 06:20 AM
guarj17's Avatar
I have pics on how to do it the ghetto way whiched worked great for me for months until I removed the stock sub.
http://forums.maxima.org/5th-generat...reo-issue.html
of course getting the new relay is prob your best choice, but this worked perfect for me.
Old Apr 9, 2012 | 05:19 PM
Thanks a lot man!! I did this a couple days and it worked, haven't had any problems since.
6spd4dsc
May 9, 2022 12:30 PM
jskirwin
Jun 8, 2016 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
