Headlight Lens Replacement
Old Apr 6, 2012 | 05:52 PM
lenart1491's Avatar
I have just bought an 03 SE with the HID's. The one side must be older because it is a little hazy/cloudy. I tried to use a few of the restorer kits out there but the results still arnt pleasing. I was hoping someone could tell me if another non-HID lens will fit the housing on the HID's. I figured I'd use the oven trick and replace the lens with a non-HID lens just because they are cheaper on ebay. Any knowledge would help, thanks.
Old Apr 6, 2012 | 07:36 PM
03VQMAX's Avatar
Just try to find a used OEM one, those aftermarket lamps/lens don't last that long.
Old Apr 6, 2012 | 07:45 PM
Genes1s's Avatar
Wet sand (600-2500 grit) then polish with orbital/variable speed polisher with good polishing compounds.
Ebay aftermarket lens are not as good as OEM, but with a good spray of clear UV protection it should last few years under the sun.
Old Apr 7, 2012 | 06:06 AM
lenart1491's Avatar
Will any of the OEM non-HID's fit? maybe from a 5th gen?
Old Apr 9, 2012 | 02:49 PM
djkevinnn's Avatar
Nope, the 5th gen housing is slightly different in size from the 5.5. One is bigger than the other, if i remember correctly, 5.5 is bigger than 5
Old Apr 9, 2012 | 03:02 PM
luvlexus101's Avatar
Which side? I have a headlight lens sitting in my room
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
KristyKarina
Aug 23, 2015 09:53 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Samedi
Aug 12, 2015 01:54 AM
