Car revving between 2nd and 3rd
Old Apr 16, 2012 | 04:33 PM
icewake's Avatar
I have a 2000 maxima, 206k miles and a new problem recently came up. My car is revving (approx. 800-1000 rpm) when shifting from 2nd to 3rd. It does it under light, moderate, and heavy loads. I have changed the transmission fluid with no luck to solving the problem. All other gear shifts are great and the car shifts like it should. Any ideas on what to check on?
Old Apr 16, 2012 | 06:13 PM
VQP0WER's Avatar
Does it go away when its cold out? Sounds like the typically transmission issue we all dealt with. No fix besides getting the trans rebuilt. Some people say installing a TransGo shift kit will help.
Old Apr 16, 2012 | 08:41 PM
icewake's Avatar
It is doing this when it is hot or cold. I never had this sort of problem until last week.
Old Apr 17, 2012 | 07:04 AM
240sxguy's Avatar
The transgo kit probably won't help if the bands and clutches are worn out. At 206k I would guess it's rebuild or replace time. It could be as simple as a band adjustment though, so talking to a reputable professional may be a good idea in this case.
Old Apr 17, 2012 | 07:34 AM
DennisMik's Avatar
It could also be the shift solenoid for that gear. Nissan issued a Service bulletin about this - NTB00-039d. Replacing the soleniods are a lot less expensive than a transmission rebuild.
Old Apr 17, 2012 | 03:10 PM
icewake's Avatar
So I went to the nissan dealership to have them run the diagnosis. What came back was "LINE PRESSURE S/V". I believe it is reading low line pressure and threw that code. My next steps are to drop the trans pan and put a battery on each solenoid to see if it pops open. Has anyone done this and what are you experience?
Last edited by icewake; Apr 17, 2012 at 03:13 PM. Reason: edit-one more note, this did not throw the check engine code but he was able to pull it with the consult II
Old Apr 17, 2012 | 03:49 PM
BigLou55's Avatar
most just replace the solenoids if you getting codes for line pressure, I don't blame you though keep going with your diagnosis to ensure you have located the problem. But if it ends up being the issue you can get the solenoid repair kit for 77 bucks(includes everything you need except the tranny pan gasket and fluid ) plus shipping from TriCities Nissan in Tennessee. Good luck
Old Apr 17, 2012 | 03:59 PM
icewake's Avatar
Replacing the solendoids is what I believe is my first option. Since the current transmission has 206k on it and I can hear a slight squeel every now and then, would any of you recommend buying a used transmission from a junkyard and having it installed? What would that cost approximately be?
halfpol
Oct 17, 2022 12:16 PM
Lakersallday24
Jun 16, 2019 01:35 AM
acw
Aug 13, 2015 12:50 AM
laparka66
Aug 6, 2015 09:36 AM
halfpol
Aug 5, 2015 08:24 PM
