TURN SIGNAL SWITCH PROBLEM!!
Old Apr 17, 2012 | 08:37 PM
BlueMaxSE's Avatar
Okay, push the hazard button signal lights flash outside and on dash. same thing when using the the key fob lights flash. using the turn signal switch hear no clicking no lights flash on dash or outside. no fuses blown. everything else on the switch works as far as controlling headlights, fogs, etc... any inputs would help. don't wanna go to dealer just yet for help. put a new turn signal switch on order through dealer just in-case that's it. Thanks in advance.
Old Apr 17, 2012 | 08:58 PM
bellis's Avatar
Check the actual flasher itself
If the flasher is not connected you will get the exact symptoms your having. Did you install a stereo or have the dash apart recently?
Old Apr 17, 2012 | 10:19 PM
TunerMaxima3000's Avatar
No, he said the Hazard switch works, which means it cant be unplugged.
OP, it sounds like you've got a bad Flasher Relay, it's under the steering column area, by your feet, where the fuse panel is. It'll be hard to find because it's not clicking (easiest way to track it down, normally).
In the picture below, I'm pretty sure the Relay is the one in the center between the Fuse panel and the SECU, with nothing directly around it.
P.S. This is a generic type 3 post flasher relay, you DO NOT need to pay a huge buck at the dealer for this, any parts store will carry them. However, be warned, aftermarket ones are louder (clicking noise) than stock.
Old Apr 18, 2012 | 07:32 AM
Chris Gregg's Avatar
Get Off My Lawn
If you do end up needing a turn signal stalk, I have a oem one BNIB. Let me know.
Old Apr 22, 2012 | 12:21 AM
BlueMaxSE's Avatar
Thanks for the help guys. replaced the flasher relay and the turn signal switch and still no joy!! aaahhhhh!! found a wiring diagram from a 99 max signal system. it says wiring goes from switch to hazard switch through fuse(which is good) and hazard switch is good. if anyone can help thanks alot ahead of time!!
Old Apr 22, 2012 | 06:14 AM
Get Off My Lawn
Great example of why not to just throw parts at a problem.
Time to get a volt meter.
Old Apr 22, 2012 | 12:09 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
^ I concur with the above statement. But just as a last quip does you sidemarkers and taillights turn on when you turn on the headlights? You might just want to cheack all of your fuses both in the car and in the engine bay.
Old Apr 22, 2012 | 12:19 PM
TallTom's Avatar
Just curious, are you using OEM style bulbs or LEDs?
Old Apr 22, 2012 | 04:10 PM
Agreed, but in this case, the likely cause from his OP was the Flasher relay. And they're about $6, and super simple to change.
Well worth the attempt in that particular case.
Either way OP, the 1999 and 2001 Maxima's are different, obviously, and the wiring is NOT the same.
nicoclub.com/fsm <<< All of the information you'll need for your car, including the wiring diagrams, and that picture I linked you above.
Old Apr 22, 2012 | 07:13 PM
BlueMaxSE's Avatar
i'm using LEDS that Shinjiduo installed and sent to me. he does great work. check my photos.
Old Apr 22, 2012 | 07:29 PM
Have you tried putting the stock bulbs back in!??
Old Apr 22, 2012 | 07:31 PM
TallTom's Avatar
How long ago? If you still have your OEMs, put them back in to see if it makes a difference.
Old Apr 22, 2012 | 07:35 PM
BlueMaxSE's Avatar
i tried the old Gauge assy. and it still does the same thing. this sucks *** but i might just have to get the dealer to trouble shoot it then i'll fix it. i have a voltmeter i'm gonna try in the morning. thanks for you help.
Old Apr 22, 2012 | 07:51 PM
wait you have LED gauge indicators, or you have EXTERIOR LED's, or both?
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
iflexsteel
Sep 2, 2015 08:04 AM
