A/C Issues, as Acceleration. Related or Coincidence?
Old Apr 18, 2012 | 09:36 PM
Maximaum Driver's Avatar
A little background here...
I just ordered a new Nissan factory A/C Compressor, and had it installed by a mechanice friend. We also replaced the Dryer/Filter. The system has been recharged and seemed to work fine when originally tested. But that was in error.
The system cycles on and off without any reason. I am going to clean the condenser coils, but I'm not sure that would cause the system to cycle on/off like it is. The system is holding freon pressure in the designated range.
The 2nd problem goes like this:
The car was bucking when I would accelerate in 1st gear, then it died when I dropped it into neutral one day. I replaced the MAF, as I recalled the last time I had a dying issue, it was the notoriously weak MAF that came with the 2000 Maximas.
Since then the bucking/kicking dropped dramatically. I still feel it on occasion, and at times when I drop the pedal to the floor, I feel the car accelerate, then feel a quick drop in power, then it surges again.
What I don't know is if there is some set of relays that are somewhat related that COULD cause these issues to be related, or if it's just a random happenstance.
If they are separate issues, I need to tackle each of them in turn, so any good ideas of what may be causing them would be helpful.
BkGreen97
Apr 2, 2016 05:47 AM
EdRomo86
Sep 12, 2015 07:49 PM
carid
Sep 9, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
