leaky trans
Old Apr 21, 2012 | 07:24 AM
Clean00'Max's Avatar
leaky trans
leaky manual transmission. two bolts on the front seem to be dripping. even more when hot. Any idea what these bolts hold in place in the transmision?
Old Apr 21, 2012 | 08:36 AM
2damax's Avatar
I'm not sure if I will be a ton of help. However, you are being to vague. Take a pic with your phone or something. Any answer you get at this point will just be a guess.
Old Apr 21, 2012 | 08:48 AM
nelledge's Avatar
"I'm just sayin'..."
Dollars to donuts that is your upper oil pan leaking. Even a RMS would be a more likely candidate. How many miles on the upper pan seals?
Old Apr 23, 2012 | 03:32 PM
piggylover1985's Avatar
What does the oil from the leak looks like ? Motor oil or trans fluid ? If it's look like motor oil then it could be coming from the rear main seal. if it's trans fluid then it could be front (input shaft) trans seal.
Old Apr 23, 2012 | 03:54 PM
aackshun's Avatar
By the time the oil reaches the access port/flywheel inspection plate I'm thinking of you can not tell based on color.
The smell is a dead give-away of which fluid it is.
Input Shaft Oil Seal, Rear Main seal are your two targets, both of which need the transmission to be dropped to find out.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Gingerheadman
Oct 1, 2015 05:11 PM
