Leaking Trunk Resulted in Bath Tub-effect in Spare Tire Well [Pic]
Old Apr 21, 2012 | 05:07 PM
gavin68's Avatar
One of my tail lamps is cracked and rain water has been collecting in the trunk's spare tire well for a few months now. Now there's this mess...
I've been bucketing water out of it, but there's still some and is inaccessable. Also, I cannot get the spare tire out. Any advice?
Old Apr 21, 2012 | 05:24 PM
02pearlmax's Avatar
If you crawl under the rear of the car (use ramps or a jack for easier access) you'll see a black rubber grommet on the underside of the spare tire well. Remove that and the water will drain out.
Old Apr 21, 2012 | 05:27 PM
03VQMAX's Avatar
This
Old Apr 21, 2012 | 05:45 PM
gavin68's Avatar
Oh, ok. Sounds easy enough. Thanks
Old Apr 21, 2012 | 08:14 PM
L_U_D_I_AMaxima's Avatar
No no no no no no he needs a gold fish in there now... lol just kidding my old accord was actually worse than.... every time it rained the carped would be soaked
Old Apr 21, 2012 | 09:17 PM
MAXC's Avatar
you get that much water in the trunk from a cracked tail light????? I think you need to check some other things here. I may be wrong but this just doesn't sound right. Are any of the trunk liners wet? How does the trunk weather seal look? any holes in the trunk floor? Im just throwing some things out there cause i really doubt its the crack.
Old Apr 21, 2012 | 09:50 PM
bgsl1ck's Avatar
Maybe the trail light its missing
Old Apr 22, 2012 | 01:06 AM
Kuhn_man's Avatar
is the cap turning or does none of it move
Old Apr 29, 2012 | 03:59 PM
gavin68's Avatar
It was actually a defective Driver-side tail lamp. Apparently that had been building up for years. Both lamps are replaced now.
and LOL at the goldfish suggestion. Honestly if an autobody shop charges too much to repair this, I'm just going to embrace this whole thing, install a water heater and a few jets, and call it a jacuzzi.
Old Apr 29, 2012 | 04:00 PM
gavin68's Avatar
I'm not sure. Should I be trying to move the bolt or the plastic white thing?
Old Apr 29, 2012 | 04:10 PM
cjandura's Avatar
turn white thingy to left
Old Apr 29, 2012 | 04:47 PM
DennisMik's Avatar
As I said in your other post, let the air out of the tire the take the pressure off of the white retainer disk
Old Apr 29, 2012 | 05:02 PM
03VQMAX's Avatar
Make sure you put a lot of sealant on the lamps, that causes a lot of leaks as well
Old Apr 30, 2012 | 11:31 PM
Infowire's Avatar
there is a drain plug in the bottom of the spare wheel area... to drain all that. =P Should be under the wheel.
Matt93SE
May 24, 2019 02:58 PM
Former3G
Oct 26, 2015 11:34 PM
homeyclaus
Sep 3, 2015 06:15 PM
mls277
Aug 11, 2015 07:18 PM
