What is this bolted to the motor?
Old Apr 29, 2012 | 06:33 PM
RSpi's Avatar
I'm trying to help a lady that was hit by someone running a light. She has a '01 Maxima and I replaced the accessory belt pully and bracket for her.
When I was installing the bolts on the bottom of the bracket, I seen wires hanging from the bottom of the motor behind the passenger side wheel. When I took a closer look, I noticed that the wires that was connected to some sensor that is bolted on the block. It just to the right of the oil filter and under the crank. It has 2 bolts going in it and a wire plug on the foward side. Please let me know what this is.
Old Apr 29, 2012 | 06:44 PM
J2FRESH's Avatar
ics:
Old Apr 29, 2012 | 06:55 PM
RSpi's Avatar
Here is the pic. Take with phone, send to e-mail, download e-mail, save on computer, edit pic, upload to website, come here to add pic. I guess I should have done it before you asked.
My guess would have been a knock sensor but she said that she has to feather the gas pedal to keep the car running now.
Old Apr 29, 2012 | 06:59 PM
SurraTT's Avatar
HR Swap Pioneer
crank sensor
Old Apr 29, 2012 | 07:06 PM
RSpi's Avatar
How is the car even starting with that disconnecting? Do you think that's why it wont idle?
Thanks a lot. I do appreciate your help. That goes for everyone.
Old Apr 29, 2012 | 07:17 PM
Amave's Avatar
crank position sensor ...there is another one on the transmission to the right of the radiator side motor mount
Old Apr 29, 2012 | 08:01 PM
MAXC's Avatar
I thought it was one or the other, Not both?
Old Apr 30, 2012 | 12:18 AM
knight_yyz's Avatar
Toolie
vq30 has 2 CPS, vq35 has only one
Old Apr 30, 2012 | 03:24 AM
Amave's Avatar
VQ30 has 2 crank and 1 cam position sensor
Old Apr 30, 2012 | 03:55 AM
TunerMaxima3000's Avatar
Originally Posted by SurraTT
crank sensor
Old Apr 30, 2012 | 04:18 AM
RSpi's Avatar
So back to my questions, should this bad one be making the car run rough?
Old Apr 30, 2012 | 05:12 AM
L_U_D_I_AMaxima's Avatar
I am surprised it even runs...
Old Apr 30, 2012 | 06:22 AM
2brosgixxer's Avatar
Help me understand why you have not plugged it back in? Are the wires cut or something?
Old Apr 30, 2012 | 06:33 AM
Yes it can make the car run rough from what I know. Surra would be able to ansewr that better. And yes, why isn't it plugged in???
Old Apr 30, 2012 | 08:35 AM
MAXC's Avatar
OOPS!... I had it backwards..Thanks for the correction.
Old Apr 30, 2012 | 08:47 AM
RSpi's Avatar
Yes the wires are torn apart. It even looks like part of the wires are missing. I seen one at the junk yard so I'll go cut that one off and splice them together on this one.
The lady said that somone ran a stop sign and hit her. But I don't see any other car paint on her's so I think she may have run her car up on a curb and hit something herself. IDK, just can't see why those wires would have been torn loose.
Dang car tossed the accessory belt again. All pullies are spinning freely. My guess is that the alternator is cocked (from the accident) or something causing the belt to break.
I did scan for codes and got a P1335. I guess that's the crank sensor that not plugged in.
Old Apr 30, 2012 | 12:51 PM
ShocknAwe's Avatar
crankshaft position sensor ref is under the pulley and pos is left of the oil pan
Old Apr 30, 2012 | 02:06 PM
cjandura's Avatar
wow i wonder if the crank pully is starting to seperate you know thats a common issue do a eye check on alignment
Old Apr 30, 2012 | 07:05 PM
DennisMik's Avatar
^^^ I was thinking that myself.
Old May 2, 2012 | 04:12 PM
RSpi's Avatar
Round 2 with this Maxi...
Huh? I think the wires were torn apart as a result of an accident. It looks like the car was run over a curb and into a tree or something.
Besides that, the lady had been driving the car like that since 3/1/12. That's her story anyway. Well, what got us connected was she lost her accessory belt and her brother tried to install one and stripped her idler pully bolt. When I got to it, it was binding so I though the bracket was bent causing it to bind. I got one from a junk yard and installed it for her.
Well, a few days later she said the car will no longer start and run. Now she was driving it on the battery and it was running rough so I thought maybe the wires to that crank sensor was causing it to run rough and now not start. So I went to the local junk yard and took wires from one there, installed wires and plugged in the connector, and wham, still no start.
So, the 2nd time I tried to start it I did not hear the fuel pump running, you know, when you let the key go the fuel pump will run for 2 to 3 seconds. Nothing. So I try to start it again and still no fuel pump sound. That killed the weak battery.
Now, my new questions??? Is there a easy way to check fuel pumps on these cars? Can you usually hear them when you try to start the car?
Thanks.
Old May 2, 2012 | 04:24 PM
Listen very closely near the back seat for the fuel pump to cycle. I can hear mine. A tip, turn the radio off so the power antenna does not go up when you turn the car on and drown out the pump cycle.
Old May 2, 2012 | 04:28 PM
RSpi's Avatar
Is the pump in the tank under the back seat like the Altama? I did turn the radio off and close the door. Could not hear the thing.
you're sure you 'fixed' the crank sensor wiring?
Old May 2, 2012 | 04:32 PM
our fuel pumps don't just fail. I've never actually ever heard of a maxima fuel pump failing.
Theyr'e insanely easy to get at, just remove the lower rear seat and it's right there.
Again, very highly doubt this is your issue.
Old May 2, 2012 | 04:41 PM
RSpi's Avatar
I'll charge up the battery and give it another try. The car has 197,000 miles on it but I don't think that's bad for a Maxima. One of my previous neighbors had 330,000 on his '99 Maxi and it still runs well. Has oil getting into #5 plug hole but other than that he's still driving it 50 miles per day.
Old May 2, 2012 | 04:44 PM
RSpi's Avatar
I'm sure I spliced in new wires to what was there. I cut the wires about 4 inches back from the break and spliced them into the plug from the jy car. Not sure how to test them 100%. Besides that, she claims she was driving the car with those wires broke for 60 days so I doubt that's the issue.
Old May 2, 2012 | 05:11 PM
RSpi's Avatar
On my car, the fuel rail runs right across the front of the motor and there is a fuel pressure valve stem on the end of it. I can screw a gauge in there and read the pressure. Is there a line or something that I can disconnect to see if there is pressure on the system?
Old May 2, 2012 | 05:19 PM
I'd think more likely that the wires were pinched in the accident and only recently fell off.
That, or they were damaged when her brother, you, or whoever was messing around with the belt tensioner, etc.
Or both.
In either case I'd jsut be double checking that before you go chasing any other gremlins.
Old May 2, 2012 | 05:20 PM
Here, you need this, read up, everything you'll ever need to know with step by step instructions:
www.nicoclub.com/fsm
Old May 2, 2012 | 06:46 PM
RSpi's Avatar
Ok, I'll check that out. Thanks for the link.
When I first seen the car and looked at the missing belt, I looked under the car and seen those wires torn apart. I asked the lady about the wires hanging down and she said they were like that for weeks. So she was driving with the front crank sensor wires torn apart.
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
