Transmission axle seals.
Old May 10, 2012 | 05:29 PM
L36's Avatar
L36
Hello.
How hard is it to replace the axle seals? I'm being told its a PITA to install the new seals...
Thanks.
Old May 10, 2012 | 05:41 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by L36
Hello.
Thanks.
I didn't replace them
If it's leaking then I guess you have to, but if you're just replacing axles, then I wouldn't bother.
Old May 10, 2012 | 05:49 PM
nelledge's Avatar
"I'm just sayin'..."
Hello.
Thanks.
Relative to what?
Old May 10, 2012 | 05:59 PM
L36's Avatar
L36
Originally Posted by nelledge
Relative to what?
Replacing the power steering pump, or alternator ect.
Il have most things torn down, im being told that inserting them into the trans can be tricky.
Old May 10, 2012 | 09:04 PM
StevieB's Avatar
They were a pita to replace on a 4th gen, and I have no reason to believe they'd be any less so on a 5th. I had new seals on hand when I replaced my 02 axles last Fall, but the old seals weren't leaking so I was careful not to damage them when removing/inserting the axles. The passenger side seal is hard to get at, the driver side is easy to access, but unless you have the correct size seal driver it's hard to seat the damn things squarely. To be fair I didn't use a seal driver when I changed them on the 99- maybe I'd think it was a laugh with the right tool.
Old May 10, 2012 | 11:07 PM
Blue Mesa's Avatar
Ive had leaky axle seals for about a year now, but the fluid loss is minimal.
I take it you have to remove the axle in order to replace the seal?
Old May 11, 2012 | 06:03 AM
L36's Avatar
L36
Yeah, Ive already removed them, just wondering if installing them back would be a pain under the car. I'm doing timing tensioners on my 04 max and got another 6 speed because of bearing whine. Now, i wont get the seals til Monday from the dealer, but i want to put the engine and trans back now.
Old May 11, 2012 | 06:47 AM
nelledge's Avatar
I know it sucks to wait, but I would. You'll kick yourself if you slap it all back together and it leaks 3 months from now when you're going through some dramatic life-change or crisis. Things happen to go that way.
They are a little tedious. One thing to note when you go to install them... Be patient. It's not that hard to ruin one in a quick fit of frustration. Fortunately, I have three local dealers and they stock them.
Old May 11, 2012 | 10:02 AM
L36's Avatar
L36
Well the engine and trans are in the engine bay, just resembling the stuff now.
Old May 11, 2012 | 09:12 PM
Bad *** Newb
Did you edit the thread title :|
Old Aug 7, 2014 | 04:19 PM
ghoff08312's Avatar
Is the axle seal supposed to seal tightly around the axle shaft? A mechanic keeps telling me it should but the hole in the seal is not even close to the axle diameter.
Old Aug 7, 2014 | 04:27 PM
Fakie J Farkerton's Avatar
Nice necropost.
The seal will not be 100% tight around the axle, but you should not see any leaks.
Old Aug 7, 2014 | 09:55 PM
DennisMik's Avatar
The seals should touch the axle. Think about it - if there is a gap, how can it seal?
The left and right seals are not the same. The left side (driver) has a 1.535 inch opening, while the right side (passenger) has a 1.299 inch opening.
So if you put a left side seal on the right side, you will have a gap and an oil leak.
left side - Nissan part # 38342-81X00
right side - Nissan part # 38342-81X01
Check prices, amazingly Nissan has the lowest price.
Old Aug 8, 2014 | 06:22 PM
ghoff08312's Avatar
Axle is after market, seal is from nissan and is for the driver's side. The axle is obviously for the driver's side (length). Seal hole is significantly larger than the axle shaft.
Old Aug 8, 2014 | 07:13 PM
DennisMik's Avatar
Get some calipers and measure the axle shaft that goes into the differential and see what you have. I've never heard anyone say they got a mis-sized axle, so I would have to say that you did not get the correct seal.
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
Pied
Sep 26, 2015 03:29 PM
