Just a simple question about my climate control...
Old May 14, 2012 | 08:14 PM
BlackedOutMaxSE's Avatar
I have a 02 max and I know that there are two types of climate control units. There is the one without the screen(the one i have) and it has the slider to change from cold to hot.
Then there is the one with the screen and it has the **** to change from cold to hot.
Like this:
I was wondering if this is compatible with my car?
The wiring looks exactly the same but I know some things cant be that easy lol
I would like to know before i bought this and its not going to work then im stuck with something that i cant even use...
Any advice or information will be most appreciated, thanks!
Old May 14, 2012 | 08:40 PM
DennisMik's Avatar
You have the basic, manual climate controls. You are wanting to put in the auto climate controls. Realistically you can't. You would have to change the wire harness under the dash for starters. There are 3 temperature sensors and 1 sunlight sensor you would have to add and swap put the blower motor resistor for a fan motor amplifier unit.
Old May 14, 2012 | 08:47 PM
Gil's03Max's Avatar
Whats the point of wanting to put the auto climate control thats pictured? I have the manual one like you do and it works perfect and i actually just bought the blower motor resistor which goes bad all the time on our cars and it was $60 because i have the manual climate control. The price for the auto climate control blower motor resistor was $180 (3 times as much). Theres nothing better or more convenient about the auto climate control you're still pushing buttons just like the manual one.
Old May 14, 2012 | 09:09 PM
DjHackStyle's Avatar
I have the Auto unit and i really wish i had the manual one, u cant use the heater and close the vents at the same time, if u do the air conditioner comes on, so u either have heat and smell all the old cars black exhaust or u just drive freezing inside the car and not smell that old bus in front of you, horrible system trust me
Old May 14, 2012 | 10:26 PM
TunerMaxima3000's Avatar
This. Right on the money.
Huh? What's the point of power windows? What's the point of power locks? their manual versions work just fine, and are cheaper to replace if they go bad also.
Auto climate control is awesome. You have a neutral setting for almost all temps and you just leave it alone, it adjusts by itself. No turning the heat up/down, fan up/down constantly to adjust because all of a sudden it's too hot, or it's too cold, then you realize that the setting you just adjusted to isn't just right and you have to readjust. Then you change speeds and you have to change it again.
Manual climate control is a HUGE PITA. Once you go Auto, you will dispise the manual one, trust me. If my maxima didn't have it, well, I wouldn't have bought it. AND if for some reason I DID, I'd be swapping to Auto regardless of work involved.
Old May 15, 2012 | 05:16 AM
Alright, thanks everyone. I just wanted to know, i'll stay with my manual one then.
Old May 15, 2012 | 05:21 AM
Also, i was wondering if anyone knows how to change the lights inside the manual climate control or can direct me to the right thread to show me how?
thanks
Old May 15, 2012 | 07:14 AM
http://forums.maxima.org/5th-generat...-works-19.html
http://forums.maxima.org/5th-generat...ad-w-poll.html
Old May 15, 2012 | 07:24 AM
Is there a place or website i can buy a kit?
The guy you mentioned in your thread, he is never online. It is hard for me to get in touch with him.
Old May 15, 2012 | 07:27 AM
cjandura's Avatar
superbrightleds.com and automotiveillumination.com first place is best
Old May 15, 2012 | 07:30 AM
Sorry that im asking so many questions but what do i look for exactly?
are they individual bulbs that go into the climate control or is it one big strip of bulbs?
Old May 15, 2012 | 07:33 AM
Amerikaner83's Avatar
Take your time reading through those threads...your answers are there.
Individual LEDs, you'll get like 4 of them I think.
Old May 15, 2012 | 07:36 AM
Are you talking about the gauge cluster in my dash?
I bought 4 of them already, the cool white or something like that.
I just dont like that dull color light coming from my climate control unit. Some of the buttons on there dont even light up...
Old May 15, 2012 | 07:37 AM
No, I'm talking about your climate control.
Old May 15, 2012 | 07:38 AM
Oh okay, just making sure because i was getting a little confused, sorry.
are they the same bulbs as like the ones in my gauge cluster?
Old May 15, 2012 | 07:48 AM
They might be but I highly doubt it.
Read thru the threads.
I did my climate control...also manual like yours, with white background (4 leds) and blue indicators instead of the factory green (8 more LEDs), I used two different types...one type for the backlighting and one for the indicators.
If you don't feel comfortable soldering then hope there's a plug and play version for you, cuz I soldered mine in to get full 360* illumination from my backlighting.
Like I said earlier, read through those threads...they contain the answers to every question you've asked so far, mmmkay?
Old May 15, 2012 | 07:51 AM
Thanks man, I can have someone solder for me if anything.
I'll read thru the threads and see if i can find the exact bulbs to buy.
Old May 15, 2012 | 07:54 AM
Old May 15, 2012 | 08:00 AM
cjandura's Avatar
it depends but if you look in them threads Tuner posted you'll see 2 ways to do it also you will see a complete conversion all leds changed and a plug n play version
Old May 15, 2012 | 08:11 AM
I'll read thru them, thanks man
Old May 15, 2012 | 08:19 AM
You will want 360 degree LED's from Superbright LED's. BUt you'll have to solder and install these yourself, it's custom but not too complicated.
Alternatively, you can contact Shinjiduo, he will make them for you and send them to you. His prices are very reasonable and he does very very good work.
Old May 15, 2012 | 08:32 AM
I have tried to get in contact with Shinjiduo before be he has never got back to me.
Old May 15, 2012 | 11:21 AM
Then do it yourself. He's on here often, he's probably just busy dude. Try him again.
9aj9
Apr 5, 2020 12:11 AM
mikeg75
Nov 30, 2015 05:12 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
