passenger side motor mount
Old May 17, 2012 | 12:40 PM
arlan's Avatar
hi i had this clunking noise coming from passenger side, replaced the endlink, from reading forum most likely its the passenger motor mount
from looking at diagram
http://www.courtesyparts.com/maxima-...1958_1963.html
it looks like i need to get this one? thanks
http://shop.advanceautoparts.com/web...RPENGPAMS_____
Old May 17, 2012 | 01:12 PM
03VQMAX's Avatar
Yeah that's it
Old May 17, 2012 | 01:24 PM
arlan's Avatar
Originally Posted by 03VQMAX
Yeah that's it
thanks
for those who interested found same one for cheaper from amazon
http://www.amazon.com/Beck-Arnley-10...7286135&sr=8-1
Old May 18, 2012 | 05:06 AM
LongoTE's Avatar
I was wondering how difficult replacing this motor mount would be.
I have terrible front end clunking and i have already replaced the swaybar bushings and endlinks. THe passenger motor mount looks squished from being so worn but idk what it looks like normally.
Ill upload a pic once i get home today to see what anyone here has to say about the condition of it. If it is an easy job i might just end up replacing it anyway and if it only reduces the clunk, then i can focus on the motor mounts on the crossmember. The clunk kinda feels like the engine is bouncing around so i hope this is it. It really prevents me from fully enjoying the ride.
Old May 18, 2012 | 07:04 AM
cjandura's Avatar
get full set from amazon make sure you get a set for the MT trans so you dont have to worry about the electric mount.they are easy to change
Old May 18, 2012 | 08:07 AM
TDMIIG's Avatar
The passenger mount is not too bad to change. I poly filled mine with McMaster Carr 60A poly for under $40. Getting to the bottom bolt on the mount can be a pain if you dont feel like taking anything apart to get to it. I ended up using two u-joints and a few extensions to get to it and busted a u-joint breaking it loose.
Old May 18, 2012 | 11:40 AM
LongoTE's Avatar
Ok so ill spare this thread from large pics and give you a >link< to the album of my passenger mount instead. So is this an easy to spot dummy flag that i haven't taken seriously yet?
As you will see, my car is close friends with corrosion so i am only going to tackle a mount if it is easy. I took a look at the mounts on the crossmember and they dont look like they need immediate replacement like this one does.
Old Oct 28, 2012 | 11:12 PM
wasdpp's Avatar
Have you replaced that motor mount? Was that causing the clucking sound? And is it more like when you hit on gas you feel like the right front wheel is falling...??
I am having the same problem and my passenger side motor mount looks exactly like yours...
Old Oct 30, 2012 | 04:01 PM
joeltender's Avatar
had the clunk for 3 yrs, replaced mount still there, finally replaced ball joint and cut off drive side endlink that had never been re-greased..........voila.
drives better than ever over 4+ years of ownership, now with 170000 miles lol. after reading many posts assumed i had to change front and rear mounts. woulda done this 3+ years ago had i realized
Dennis Twohy
Oct 1, 2015 06:01 PM
AcuraLegend
Sep 22, 2015 04:22 PM
iflexsteel
Sep 15, 2015 03:37 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
