Where Does This Vacuum Line Go?
Old May 20, 2012 | 06:46 AM
OIFJORDAN's Avatar
Here is my dilemma, swapped a 2001 I30 Vq into my 2000 Maxima (engine threw a rod).
I can not seem to find where this one vacuum hose should go. If you are facing the front of the car looking at your oil filler cap, look right behind it and below it. It seems to be attached to a valve of some sort which looks to be attached to the lower intake manifold. Mine is but and do not see where it should go from that valve. Yes I searched and tried to find vacuum diagrams with no luck. Thanks org
Old May 20, 2012 | 06:56 AM
cjandura's Avatar
pictures of the offending are are a better helping tool
Old May 20, 2012 | 07:12 AM
T_Behr904's Avatar
Old May 20, 2012 | 07:22 AM
OIFJORDAN's Avatar
How do I attach a picture? If I knew that I def would have had one up lol...but I can't figure out how. I am just using my phone as I am in the garage right now.
Old May 20, 2012 | 07:27 AM
OIFJORDAN's Avatar
Nevermind give me a few I will get it...I know I must give a link...lol
Old May 20, 2012 | 07:40 AM
Ghost_54's Avatar
Sounds like you are describing one of the vaccum hoses that is part of the VIAS system. Pic is below as well as the link to the thread describing it function and what can be safely removed and what is required to stay connected so you don't throw any engine codes ... Your engine is no doubt layed out a little different as it is a 3.0lt i30 and the pic below is of a 3.5lt Max but the principal would be the same.
Link to thread .. http://forums.maxima.org/5th-generat...nnister+delete
Old May 20, 2012 | 08:43 AM
OIFJORDAN's Avatar
Video
http://m.youtube.com/watch?v=SoAPjj-CknM
Old May 20, 2012 | 09:19 AM
Grand_hustle17's Avatar
If u have a Photobucket account (make1) save Ur pic from Ur phone there then just copy n past the "ING" code for the pic here
Old May 20, 2012 | 09:21 AM
I'm going to my car now so ill go look for that line n see where it goes... Hopefully snap a few pics...
Old May 20, 2012 | 09:36 AM
essential1's Avatar
My axles cry for mercy...
That's for the lower butterfly valves. 2000 models dont have this unless you're cali spec. If you still have your original lower intake manifold, swap this over to this motor and you wont have a problem. The 2001 upper also has that reddish/brown connector next to the black connector on the VIAS section of the upper intake manifold. Your factory 2000 manifold doesn't. Swap those over also if you prefer.
Old May 20, 2012 | 10:26 AM
OIFJORDAN's Avatar
Awesome thank you all so much. I wonder if that is why my idle has been all jacked up esp at cold start. Well when I get more time I guess I will rip this apart and swap the original ones back in AGH...LOL...MIGHT as well do the gaskets while I'm in there lol...Upper and lower. Yay! Thanks again all!
Old May 20, 2012 | 08:31 PM
just for a future search purpose in case anybody have this problem i will attach a pic helping future swappers
Edit: fingers torn up doing headers lol
Old May 21, 2012 | 02:54 AM
essential1's Avatar
Edit: fingers ashy cuz black lol
[IM]http://i158.photobucket.com/albums/t108/dnvr12/IMAG0112.jpg[/IMG]
Fixed
Old May 21, 2012 | 05:45 AM
Originally Posted by essential1
Fixed
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Taino14
Sep 24, 2015 02:51 PM
