5th Gen Ranking Thread - Bolt-on Suspension Bars
Another strut bar thread just came and went, which is both unremarkable and typical for the Org. Someone discovered the concept of a RSTB, and then the inevitable questions about value. For whatever reason, I ranked 3 similar items against one another based on personal experience and highly
subjective observation. The sequence and numbers I came to are this:
It's hard not to focus too much on any one measure of value, such as Cost, Performance or Bling. That's where things get really subjective. But It seemed like the idea might be fun to talk about, and maybe some good advice can come out of it.
And maybe we can take up other Ranking threads.
subjective observation. The sequence and numbers I came to are this:RSB > FSTB > RSTB
With a weighted ratio of: 10:03:01 respectively.It's hard not to focus too much on any one measure of value, such as Cost, Performance or Bling. That's where things get really subjective. But It seemed like the idea might be fun to talk about, and maybe some good advice can come out of it.
When sequenced by bling, obviously it's FSTB > RSTB > RSB, at 10:03:01. And when rated by which is the easiest install, it's still FSTB > RSTB > RSB.
But all that is rubbish, because the Rear Sway Bar is the hands-down best bolt-on bar for the 5th gen. Even the most dull and insensitive driver would notice the handling gains of a RSB on the car.
I don't know why but I really like the ranking of mods out of 10, and the ranking of them respectively due to their association with other mods. Though it is highly opinion based I like the idea of it. Someone with lowering springs, might rate the same mod differently due to their set up, versus someone with no lowering springs. So as long as the associated mods are listed it should hold some value.
LTB Stage II : 9
(conservatively IMO, but when I see Roch's 10 on RSB, a LTB Stage II deserves a 10 also)
you could probably apply this categorized ranking to all types of mods not just Bolt on Suspension.
LTB Stage II : 9
if a FSTB is better than a RSTB then i gotta say its a pointless thing to get because that FSTB does nothing at all.... at all... wont waste my money on a FSTB again
EDIT: like the above poster mentioned.. LTB's are boss... id much rather that than a FSTB... unless $20 from ebay just to make the engine bay more chromy, thats all it does really
If you buy a REAL FSTB, such as a solid aluminum one with no joints on it, you will notice difference in the car's response.
I.E.:
Why would they use FSTB on race-spec cars if they did absolutely nothing...?
Not just because racecar...
I.E.:
not saying it dont, hopefully you couldve read through the dramatization... from an extreme literal perspective im sure the FSTB is of some difference (one where its never felt) but with such minor and lemme emphasize MINOR difference its not worth getting unless you just wanna add to your mod list n make it look interesting (i believe that is even more effective than the FSTB)
Maybe it's just me, but when I installed my FSTB on the stock suspension, the front end definitely felt a little snappier around corners. It felt like the car was more willing to take the corner.
Once I had coilovers, you couldn't really feel anything. But prior to that, it was definitely an improvement.
Right. It essentially ties the tops of the strut housings together to reduce flex of the strut housings around corners. Coupled with a LTB, it greatly reduces suspension flex in the front end.
Now if the fstb tied into the firewall, the effect would even be greater.
Yea the ideal fstb would be a one piece design with no joints in it.
smmfh... why do they take the headlight out on drag cars??? maybe you should too n drive daily... cmon man... bro we are talking about on a maxima... im sure a FSTB works wonders on another model car, im not saying the thing does not ever work for any car made in life, that would be a broad ignorant statement, but seeing as though we are in the 00-03 section of maxima.org i only assumed we were talking about 00-03 maximas wouldnt you??? just because a performance chip work in a race car does it means it work in out lil family sedan???
The reason because of this is
a) the bar is not a one piece design
b) it is not tied into the firewall
But there is a difference between not having a FSTB on a MacPhearson suspension and having one.
The nature of the MacPhearson set-up and the way it is designed compared to a double wishbone set-up is that the load is transfered directly to the top when cornering loads are applied. A FSTB helps to tie-in both sides in which it helps reduce the amount of camber change when a vehicle corners.
BTW maxima or not maxima, the issue here is the MacPhearson suspension.
it is... did it with my stock 5.5.... did absolutely nothing... this is a point we will just have to agree to disagree... i know without any persuation for a fact you cannot feel any difference with the FSTB, and ppl here always buy a mod and it messes with there minds on how much a difference it makes... brett overe here kinda proved it... you guys clearly state how the benefit is to reduce the front from flexing, oh any ave turn, how much flex does the car really have and how much of that is reduced for you to "feel it"...
Cut the crap.
this one im gonna have to call BS on but ill repect you guys evaluation on this... ill need proof some how of this difference... aackshun is needed... when i come here and people installing a filter or a pulley and rave how the feel some random "difference" just further prooves how over exaggerated some things are... again i am not saying there is not difference at all, but its moreso minor on paper.... my evaluation of a FSTB is.... if the car was gonna loose control at lets say 100mph around some random turn because of chassis flex
then the car wouldve loss control around the same corner at 100mph also... now if we get into fine details and say the car was going 100.37mph then the FSTB may help if the car was going 100.40mph (not an actual number of where i think the car would give out but just merely expressing how minor of a difference i am talking about here)... again this is just my evaluation...
and i not saying you dont... if cattman designs a 3" header and say "hey i designed it and i say it makes a difference" would that be enough, no... again i tried it and it was hands down the silliest most pointless suspension mod i ever had on my maxima... im sure i can have my own evaluation and if none of us can show proof as to why its a difference on a 00-03 FWD nissan maxima A33 then we are both just as correct or incorrect
then the car wouldve loss control around the same corner at 100mph also... now if we get into fine details and say the car was going 100.37mph then the FSTB may help if the car was going 100.40mph (not an actual number of where i think the car would give out but just merely expressing how minor of a difference i am talking about here)... again this is just my evaluation...I am not going to continue and argue with you over something that simple physics can prove.
OF course on the street the difference is minor since the majority of people do not push their cars hard during cornering. However on an actual course, the difference is vastly greater.
I said from a literal stand point there is a difference but nothing you will feel
Brett and someone else said- it made his car (maxima) just turn better n a lil peppier
You said, it makes a noticeable difference if taken to the extreme on a road coarse but not felt just in a daily commute and not pushing the limits
whats to argue?? we all gave our evaluations on how well we think this performs yet im getting bashed for what i experience... WTF?
Fixed for accuracy, Denver, because your experience is your own. You're entirely welcome to your own opinion, but please stop misrepresenting it time and again as a "fact". That's absurd and a little ignorant... and you are certainly not an ignorant member here when it comes to the Maxima. Your opinion on the FSTB is a valid one, even if it is overwhelmingly disputed by the crushing weight of everyone else.
Fixed for accuracy, Denver, because your experience is your own. You're entirely welcome to your own opinion, but please stop misrepresenting it time and against as a "fact". That's absurd and a little ignorant... and you are certainly not an ignorant member here when it comes to the Maxima. Your opinion on the FSTB is a valid one, even if it is overwhelmingly disputed by the crushing weight of everyone else.
I have agree with you on this .. on one of my female friend 03 volvo s60 it has the front strut bar with no joints in it. Just one soild piece of metal ... and that's from the factory ..
There are some who claim to notice no difference what-so-ever. This may be entirely valid for that person's car, or a claim fueled by contributing suspension mods (such as lowering your car to the point of uselessness). Or it could simply be the result of dull senses on the part of the claimant.
How's that, Hustler?
OK, then. Let's say that for people who've installed a FSTB (or RSTB) on the 5th Gen Maxima, the consensus is that you will feel minor handling gains. These opinions may be real, or psycho-semantic. Either way, it's the majority opinion.
You've said your piece, Hustler. Rank the RSB, FSTB and RSTB against one another according the the thread intent and move on...
...assuming you have experience with a RSB and RSTB from which to gauge your opinion. Otherwise, thanks for playing.
