3rd gear crunch
Old May 22, 2012 | 11:07 AM
Grand_hustle17's Avatar
3rd gear crunch
O.k so im not aware of this being a problem with the 5MT's... i literally just finished fixing an exhaust leak 15mins ago and now driving i notice ever so random and depending on speed there is a 3rd gear crunch... what could be the cause of that... seems like when i fix one issue and another comes up that has nothing to do with the previous issue
Old May 22, 2012 | 11:09 AM
L36's Avatar
L36
Check if you have the right level of gear oil in the gear box. Make sure you're using GL-4 only gear oil. I had same issue with my 01, but i replaced the gear oil with MT-90 and my issue went away.
Old May 22, 2012 | 11:19 AM
cool ill check that out ASAP!
Old May 22, 2012 | 11:21 AM
cjandura's Avatar
check to see if the shift cable got disturbed during your recent adventure
Old May 22, 2012 | 11:22 AM
i remember from my 6MT that the MT90 is a pretty hard find unless you order it from the net... anything i can just go buy off the shelf thats good to go??
Old May 22, 2012 | 11:25 AM
VisciousMo's Avatar
Are all of your mounts good?
I have 3rd gear crunch, AMSOIL GL-4 synthetic. poly mounts except the tranny mount. Rebuilt tranny a year ago and my shifter physically moves back and forth with throttle input. Under normal driving, it won't crutch. If I'm at redline at 2nd gear and I go into 3rd....it will crunch.
I'm stumped
Old May 22, 2012 | 11:30 AM
Rochester's Avatar
My local Nissan Dealership carries Redline products... you could give your Nissan shop a call. Otherwise, here's a link to find retailsers:
http://www.redlineoil.com/dealers.aspx
Also, read up on Redline MT-85. It's a newer mix than MT-90, and I much preferred it over the MT-90 in my old Max.
Also, you probably already know this, but the more you secure your engine from movement, the smoother the shifting is.
No cable like the 5.5... it doesnt do it all the time... it actually just started like 20-25mins ago... if i shift extreeeemely early then no, but if i shift anywhere from a lil over 3500 rpms it may
Old May 22, 2012 | 11:50 AM
yea, fortunately all the mounts in the car is still good, but i will be investing in more stability parts for the motor... i will look into the redline MT85...
Old May 22, 2012 | 11:53 AM
cjandura's Avatar
6mt swap
Old May 22, 2012 | 12:03 PM
6mt swap
yea that will never happen..............
what about this here??.. $20 a quart
Old May 22, 2012 | 12:07 PM
cjandura's Avatar
For what liquid gold in a bottle?it better come with some big booty joints in bikinis to pour it in and a bottle of patrone
Old May 22, 2012 | 12:11 PM
dfj240's Avatar
Can't you get Redline from Autozone or Oreilly? I vaguely remember picking up some MT90 from Autozone a few years ago.
-Nathan
Old May 22, 2012 | 12:12 PM
Rochester's Avatar
IIRC, you need something less than 3 quarts... 2.6 comes to mind. I'm sure it's in the owner's manual.
And yeah, it's expensive stuff.
Old May 22, 2012 | 12:21 PM
-Nathan
naw bro... ro redline in the autozone/advance auto/NAPA/pepboys here lol.. i went through that search in my 6MT before lol...
http://shop.advanceautoparts.com/web...7CGRP2035_____
what about this???
Old May 22, 2012 | 12:23 PM
i think for the 5MT it was bout 1.25 gallon... if i remember correct that is lol
Old May 22, 2012 | 12:24 PM
Rochester's Avatar
Right, right... 5MT. My bad.
5 quarts. Yikes!
Old May 22, 2012 | 12:25 PM
dfj240's Avatar
140 weight is a little too heavy I think, but I can't really say anything negative about Royal Purple. Here's the proper weight in Royal Purple:
http://shop.advanceautoparts.com/web...T|GRP2035_____
-Nathan
Old May 22, 2012 | 12:33 PM
-Nathan
lol yea thats the one i meant to ask about... im busy here and sending out my resume to a recruiter so my mind is a lil clogged while texting to get a quote on fixing my rad support...
Old May 22, 2012 | 12:49 PM
5 quarts. Yikes!
thats what i said when i 1st learned that lol
Old May 22, 2012 | 12:53 PM
dfj240's Avatar
Depending on where in the country you are, there is bound to be a shop somewhere near you that sells redline. Redline is usually cheaper than Royal Purple, and IMO it's better too.
-Nathan
Old May 22, 2012 | 12:56 PM
-Nathan
im in Maryland and would absolutely loooove to see a shop that sells that
Mobile one normally sells reputable lubricants what about this??
or Valvoline... only thing is theirs aren't synthetic
Old May 22, 2012 | 01:01 PM
dfj240's Avatar
http://www.synlubes.com/redline/gearoil.html
^That place is near Baltimore. Not sure how close you are, but there are 7 different shops within 50 miles of Baltimore.
^Use that, enter your post code, and it will bring up any place within 50 miles of you.
-Nathan
Old May 22, 2012 | 01:05 PM
Galactica's Avatar
5 quarts. Yikes!
Negative. I just did my 5MT and it took less than 3 quarts. I am also running the newer Redline MT-85. I have a buddy in town that ones a performance shop and he always carries Redline. ATE Super Blue is going in the car on Thursday when I do the rotors and pads.
k cool... im closer to Washington DC than i am to Baltimore, if that gives a round about time... ive heard about that Joppa road before but not sure how close.... maybe between 30-45mins out give or take... with traffic... 2hrs lmao
Old May 22, 2012 | 01:07 PM
mmk... maybe im wrong... Ghostmax who owns a 4th gen and his bro Jaypee who owns both a 4th and a 5.5 said 5qts a while back but hey the less it is the least expensive
Old May 22, 2012 | 01:11 PM
-Nathan
that link is king shyt... that should be stickied lmao
Old May 22, 2012 | 01:15 PM
Galactica's Avatar
Oh Crap I misinform!! My bad guys! I got mixed up because I had the same questions when I did mine and it's the 6mt that takes a lot less fluid! 5mt takes 4.5qts or so! Sheit, sorry guys!...
Rochester's Avatar
Post #7
Echo... echo...
Old May 22, 2012 | 01:17 PM
Galactica's Avatar
Here's the link to it:
http://vbxmaxima.8m.com/mtoil.html
Sorry again guys!
Old May 22, 2012 | 01:18 PM
Post #7
Echo... echo...
damn you sure nuff did... idk how did that get overlooked.. my bad chester... like i said i was a lil tied up earlier
Old May 22, 2012 | 01:23 PM
dfj240's Avatar
Post #7
Echo... echo...
In complete honesty, I was giggling about this when I posted that link. Lol. I was thinking, "He must have skipped right over Rochester's post. Poor Rochester." Haha.
-Nathan
Old May 22, 2012 | 02:13 PM
2000_MAXIMA_KING's Avatar
Learn how to shift
Old May 22, 2012 | 03:26 PM
^^^thank you..... mr jimmie johnson lol
Old May 22, 2012 | 04:32 PM
essential1's Avatar
My axles cry for mercy...
Mine crunches if I downshift unless I rev match it perfectly.
You can get gl4 from Napa. It's in a white 4 quart bottle with a teal/green lable if I'm not mistaken.
Old May 22, 2012 | 04:43 PM
did that fix ur issue???
Old May 22, 2012 | 05:10 PM
036mtmax's Avatar
Order MT-85 and bleed the fauk out of your clutch and it should take care of it. It took the 3rd gear crunch out of my 5/5 permanently. I put it in my 5 speed AE trans i have now and it shifts like butter even with bad motor mounts. Its worth the money and the wait trust me. I test muled a bunch of gear oils in my 5/5 already. Hope this helps Hustle
03 6 Speed Cold Shift Crunch
Old May 22, 2012 | 05:13 PM
essential1's Avatar
It lessened the problem but didn't cure it 100%
Old May 22, 2012 | 05:57 PM
mmm
Gotcha, mines dont crunch at all on down shift and ever so random on upshifts... now that i found the vendors here ill justgo buy 2 qts maybe
Old May 23, 2012 | 07:27 AM
I have the redline shockproof in my trans, previous owner had it put in when shop did the clutch. I was confused when I first seen it since it's a minty color. Maybe you should try it, lots have had good results with it. I still crunch sometimes though but for a 20 year old trans and one thats known for crunching in almost every gear, its pretty damn guuuddd.
