Looking for alarm that works on manual cars.
Old Jan 5, 2002 | 10:42 AM
BlackMax2k1's Avatar
Thanks!
Old Jan 5, 2002 | 11:13 AM
srbarnes4ever's Avatar
Re: Looking for alarm that works on manual cars.
Originally posted by BlackMax2k1
Thanks!
If you mean an alarm with remote start that will work on a manual transmission, then see your local Clifford retailer. I know the Clifford Solaris G4 system is up to the task as I have the owner's manual. I'm sure there are others.
Old Jan 5, 2002 | 11:16 AM
Sorry, you're right, I meant remote start.
Old Jan 5, 2002 | 11:51 AM
Bman's Avatar
Alternatively you could find a place willing to install a much cheaper Automatic remote starter like I did.
***BUT: they will probably get you to sign a waiver if they do it at all - they don't want to be held liable. Because this car can now be started IN GEAR it can be very DANGEROUS if you have the habit of parking it in gear (I don't and live in the flatlands). If you try this the car will (supposedly) jump forward and smash someone's rear end, crush unsuspecting legs, run over small mammals, etc, etc.
NOT for the forgetful or those who park in gear habitually.
Old Jan 5, 2002 | 12:25 PM
MichaelAE's Avatar
Re: Re: Looking for alarm that works on manual cars.
What does the system do to ensure safe starting of a manual? I'm assuming it doesn't depress the clutch. I was reading on Clifford's web site, but it doesn't exactly explain.
Old Jan 5, 2002 | 12:41 PM
Re: Re: Re: Looking for alarm that works on manual cars.
I believe there is a wire that connects to the parking brake
signal for the light on the dash.
Old Jan 5, 2002 | 12:53 PM
MichaelAE's Avatar
Re: Re: Re: Re: Looking for alarm that works on manual cars.
I just read through the manual. Even if you wire this thing up to a manual, its a real pain in the a$$. In order for auto-start to work, you've got to leave the car running, engage the parking brake, put the car in neutral, press button #1 twice, then press button #3 once, then exit the car and engage the alarm with will cut the engine and set the car ready for autostart...then you have to call your Aunt in Detroit and have her check to see if her refrigerator is running. Hassle-city.
Old Jan 5, 2002 | 03:25 PM
Bman's Avatar
Re: Re: Re: Re: Re: Looking for alarm that works on manual cars.
Exactly why I said "screw it" and went with my dangerously convenient way It's a lot cheaper too.
It's so complicated because it has to know you're not in the car and it's locked, so that no one can put it into gear between then and when you remote start.
One salesman once told me you could hook up the parking brake switch to a magnetic switch (like those used in home doors for alarms) that was attached to the stickshift and a bracket so that it would know it was in neutral.... I just nodded and thought he was full of it, since he also thought the hoodpin was also a safety switch.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
