Stuck axle....need suggestions
Old May 24, 2012 | 08:24 PM
The Law's Avatar
I R The Law
So I was trying to take out my driver side axle because I was going to send it back to Raxles to have it warrantied. Well I tried to pull out the axle and I was able to yank out the joint that is closest to the transmission (if this makes sense) but not the entire axle. I tried to use a big flat head to pry the axle housing off the transmission but to no avail. Now I PB blasted it and will let it sit overnight to hope that it might loosen it a bit. Any other suggestions guys?
Old May 24, 2012 | 08:44 PM
Keep pullin'.
Old May 24, 2012 | 08:56 PM
clintb3astwood's Avatar
Oh Damn, my friend had this saaame issue.....the end result was not good. Might be that clip at the end of the axle causing it to be stuck.
Old May 24, 2012 | 09:21 PM
The Law's Avatar
I R The Law
Um...... What was the end result?
Old May 25, 2012 | 09:42 AM
Tranny was taken down and the axle was torched, new tranny and new axle. :x he had a 5th gen auto, so Idk hopefully your situation is different.
Old May 25, 2012 | 09:44 AM
StevieB's Avatar
Do you happen to have a slide hammer handy?
Old May 25, 2012 | 09:48 AM
essential1's Avatar
My axles cry for mercy...
It happens to the best of us man. There are 2 ways I use to get it out when it's stuck like this...
Jack the car up as high as possible. Use jackstands of course. Then with my 18" pry bar, wedge it between the axle and tranny from underneath. Then brace yourself as best as possible and KICK THE **** OUTA THAT ****!!!!! till it flies out of the transmission smacking you square in the chest.
Or...
Jack both sides up, then remove the passenger axle. If you look threw this hole, you can see the end of the axle on the other end. Then find the longest screwdriver you can, or anything that will make it to the other side. Then tap the end with a hammer and it will pop out. I usually use this method when the transmission is off the car already though.
Old May 25, 2012 | 10:09 AM
FastnFuriousMax's Avatar
Hey Lawrence. I thought you died or something. You never post anymore.
Or...
This. I have used both methods on stuck axles.
On the 4th gen the Haynes manual recommends you take out the passenger axle and smack the driver's side axel out.
good luck. Nothing like a 30m job that turns into a two day job.
Old May 25, 2012 | 01:23 PM
EuroDriver's Avatar
If you end up having to take out the passenger axle, I would suggest using a solid bar (metal or wood) that's long enough to give you good leverage for a good-sized mallet hammer in your other hand.
Old May 25, 2012 | 02:21 PM
The Law's Avatar
I R The Law
I'm going to go rent one with a cv boot driver
Old May 25, 2012 | 02:22 PM
The Law's Avatar
I R The Law
LOL! My name is Lawrence as well and I haven't been on this forum in ages either.
Old May 25, 2012 | 02:27 PM
I think he was talking to you
Old May 25, 2012 | 04:24 PM
The Law's Avatar
I R The Law
I don't know how he'd know me since I'm rarely on anymore....but who knows? haha!
Old May 25, 2012 | 05:07 PM
Trini Boom's Avatar
These...any other way just puts your tranny at risk.
Old May 25, 2012 | 05:15 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I remember you if it's any consolation
Old May 25, 2012 | 05:47 PM
Don't mind his username and join date
Old May 25, 2012 | 07:16 PM
Are you auto or 6 speed?
Old May 25, 2012 | 09:14 PM
essential1's Avatar
How can anyone forget a max with te37s? Lol
Old May 26, 2012 | 07:53 AM
zero2sixtyZ's Avatar
You embarrass me.
I would just give up and sell me your wheels...
Old May 26, 2012 | 07:54 AM
essential1's Avatar
Then send your rays to me right after. Everybody wins.
Old May 28, 2012 | 08:37 PM
The Law's Avatar
I R The Law
haha!
Old May 28, 2012 | 08:38 PM
The Law's Avatar
I R The Law
I'm auto; sadly
The Law's Avatar
I R The Law
HAHA, I guess that's true. Not often do you see TE37s on a max
Old May 28, 2012 | 08:39 PM
The Law's Avatar
I R The Law
I'll trade you my wheels for your car, done deal!
Old May 28, 2012 | 08:43 PM
The Law's Avatar
I R The Law
BTW! I got the axle out by using a CV boot driver and a slide hammer! Worked like a champ!
Old May 28, 2012 | 10:57 PM
LIKE A BOSSS!! Nice man, you definitely lucked out.... sadly my late friend didnt have such luck. So what happens now? and what caused it to get stuck in the first place?
Old May 29, 2012 | 12:00 AM
The Law's Avatar
I R The Law
I've sent them back to Raxle to have the axles checked out and replaced.
I think it was that stupid C-clamp that goes into the transmission that was giving me problems.
Old May 29, 2012 | 07:22 AM
StevieB's Avatar
The Law
Glad you got it out. Did I win your wheels?
Old May 29, 2012 | 07:27 AM
The Law's Avatar
I R The Law
The Law
Yes, you won a picture of my wheels
Old May 29, 2012 | 07:34 AM
Crusher103's Avatar
Did you get it out? The driver side is always a PITA.
Crowbar is how i get my axles out these days if that doesnt work then i take out the passenger and get a metal pipe or a couple of rachet extensions and just tap the axle with the back of my rachet or a hammer, works like a charm.
Old May 29, 2012 | 09:32 AM
The Law's Avatar
I R The Law
Yeah, I was able to get the axle out. I used a CV Boot Driver and a Slide hammer that I rented from an autoparts store.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
