p0300 random misfire
Old May 27, 2012 | 01:52 PM
luke03maxse's Avatar
i have a 2003 maxima se 6 speed. it has a random misfire and burns oil. i changed all 6 coils and plugs. i was thinking it could be the camshaft position sensor and/or the crankshaft position sensor? any advice or suggestions will be great. thanks.
Old May 27, 2012 | 02:09 PM
dfj240's Avatar
Search. There are several threads about this already.
In any case, what other symptoms are you encountering? Sluggish acceleration? Pinging? Hesitation? Surging? Low Idle? High Idle? Jumping Idle? Running Rich? Lean?
It could be the crank position sensor, and/or the cam position sensors, but you will need to do quite a bit of testing and process of elimination to find out for sure.
-Nathan
Old May 28, 2012 | 06:46 AM
wirelessdude04's Avatar
Yup so many threads about this..
Check plugs, coils, connectors, test harness etc..
Im going thru this right now with a misfire and replacing my engine harness next.
Old May 28, 2012 | 11:01 PM
NyMax03se's Avatar
im going thru the same thing same code and oil burner ... i did the same as you and did the plugs didn't do the coils but was going to do it next. I did get the camshaft sensor changed in hopes of clearing the code but it did not work.. ive searched and taking it to 2 mechanics and neither of them could fix the code... serious head scratcher... bump for some good answers on this problem...
Old May 29, 2012 | 12:01 AM
026spd's Avatar
does the ses light come on then goes off after a day? cause thats what mine has been doing since January
Old May 29, 2012 | 03:33 PM
NyMax03se's Avatar
it stays on for a while then off for a few days comes back. i even seen it blink while driving it which is throwing me for a loop... but the same code... every time: mad:, since i bought the max... 1 1/2 yr
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
