I need a new engine??
Old Jun 5, 2012 | 08:35 PM
NyMax03se's Avatar
So after about 700$ spent on a Check Engine Light(P0300 random misfire) taking the car to different shops and trying different fixes i still end up with this blasted light. I can't get this fixed and i really don't want to sell the car. I took it to a mechanic a good buddy of mine refered me to and he said i need a new engine. Apparently there is oil getting into the spark plugs and thats what's causing my CEL light to come on. So he says to fix it to options 1. rebuild the motor or 2. Swap.. I come to you maxima guru's in hope of an answer or a reference to a mechanic in NYC that knows maxima's like the back of there hands. So i can get a definitive answer to this and either swap this sucker or fix it thank you.
ETC.
2003 maxima SE 6spd
121000mils
Old Jun 5, 2012 | 08:41 PM
maxx0831's Avatar
If there is oil leaking into the sparkplugs, why dont you changed the valve covers to the 04 maxima valve covers. It's a common problem on these engines. It has even happened to me.I upgraded to the 04 valve covers and so far its been good.
Old Jun 5, 2012 | 08:46 PM
NyMax03se's Avatar
was your car throwing a misfire code too?
Old Jun 5, 2012 | 08:54 PM
TunerMaxima3000's Avatar
Oil in spark plugs is 95% of the time from bad valve covers. Not a big deal if htat's what it is.
Replace with the 2004 style which is a better design. It's also a LOT cheaper.
First thing you should be doing is a Compression test though. If it's ok then do the parts causing the problem.
Sounds like your mechanics are morons.
Buy right from the dealer it's cheap. make sure you get a gasket with it
You'll also need an Upper Intake Manifold Gasket while you're in there, as it needs to be removed to do the rear Valve cover base.
Find out which one is leaking and replace it. While you're in there replace the spark plug (s)
then re-check. If code persists you hvae one or more bad ignition coils, these mount right on the valve cover base and they have a tube on them that connects to the spark plugs. They're another common issue on these cars as they age.
Old Jun 5, 2012 | 08:57 PM
NyMax03se's Avatar
i really want to take it to someone who knows nissan for a good second opinion.
Old Jun 6, 2012 | 07:07 AM
2damax's Avatar
Not to many people know nissans better than people here giving advice. Your mechanic is telling you to replace your engine for an EXTREMELY common problem. Replace the rear valve cover and gaskets like tuner said. If the code persists, figure out which coil needs to be replaced like tuner said.
What did you already spend $700 on? Coils?
Old Jun 6, 2012 | 07:26 AM
thai32's Avatar
I have the same Problem then the knock comes took it to the dealer they say need a new engine. before that i took of the valve cover and change the coils and the spark plug but when all done n started up still the same CEL light come on checked again it tells me it the Cam sensor is bad , so i decide to do an 09 vq35 engine swap
Old Jun 6, 2012 | 07:34 AM
tigersharkdude's Avatar
You swapped your motor because a cam sensor was bad? you must rolling in money
Old Jun 6, 2012 | 07:59 AM
cjandura's Avatar
Like your gonna get this to work FFS!! its only been done 1 time
Old Jun 6, 2012 | 08:38 AM
NyMax03se's Avatar
I have gotten the front valve cover ,the crank sensor,front cam sensor, 2 coils and various diagnostic charges from different mechanics not to mention the labor for all of these things.
Old Jun 6, 2012 | 08:39 AM
NmexMAX's Avatar
dot dot dot ...
Any reason why you got the front valve cover?
Typically, it's the rear that begins to leak.
Also, no coils on that list?
Old Jun 6, 2012 | 08:40 AM
NyMax03se's Avatar
^ see what i mean
Old Jun 6, 2012 | 08:43 AM
NyMax03se's Avatar
i have changed two coils to see if the misfire would change from P0300 to some like p0301,0302,0303,etc... i would rather have the check engine throw thoughs codes becuase at least i know whats wrong with it and not some random ****. the Mechanic said it was leaking to so i was like go for it just to keep it running right on bothside.
Old Jun 6, 2012 | 09:19 AM
NmexMAX's Avatar
dot dot dot ...
Maybe change the rear bank also.
New boots and plugs and coils.
Keep an eye on your oil level too.
Old Jun 6, 2012 | 09:22 AM
NyMax03se's Avatar
so i just went outside to check and see if the spark plugs had oil on them they dont. So i called the mechanic he apparently already did a compression tests on my engine and all 6 cylinders are losing compression. that's what is causing the oil to get on the spark plugs and the misfire that i have.
Old Jun 6, 2012 | 09:31 AM
from the sound of things...your mechanic is trying to rape you iMHO
Old Jun 6, 2012 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
Ask him what the values were for each cylinder.
Old Jun 6, 2012 | 09:41 AM
morris369's Avatar
To me it sounds like hes telling you the plugs are gettin oil on them in the cumbustion chamber, not on the coil side. If you have bad rings, there's your problem, for loss of compression on all six cylinders, sounds fishy.
Old Jun 6, 2012 | 09:42 AM
oldngivout's Avatar
Willing to learn
That just sounds too simple. The front three plugs are easily accessible, but you must remove the upper intake to get at the rear ones. Did you do that?
Old Jun 6, 2012 | 10:16 AM
maxx0831's Avatar
seems like your from NY, If your in the queens area you can drive out to long island to Harjit's shop. You can contact him I believe on here but definatly will reach him on nycmaximas.org. His username is Sum1punjabi. He has his own shop and everyone on there can vouch for him including me. you can pm for more details.
Old Jun 6, 2012 | 11:12 AM
NyMax03se's Avatar
the mechanic said ^ this word for word just in spanish.lol
i only checked #6 in the back. i have to go to work so i wasn't trying to rip down the engine now.
Old Jun 6, 2012 | 11:24 AM
^you only checked the one under the UIM eh?
Old Jun 6, 2012 | 11:35 AM
NyMax03se's Avatar
the 3 in the front and #6 in the back
i went on nycmaximas alot of good words about that dude. i think i might take that trip ...
Old Jun 6, 2012 | 11:38 AM
how did you take #6 w/o pulling the UIM
Old Jun 6, 2012 | 11:52 AM
NmexMAX's Avatar
dot dot dot ...
2, 4, & 6 are in front, and 1, 3, & 5 are in rear.
# 5 might be accessible with the IM still on, heard of it happening once on here. But, I doubt you could actually remove the spark plug with as little room as there is in there.
Old Jun 6, 2012 | 12:09 PM
NyMax03se's Avatar
Sry I meant to say 5. The coil comes rite out very small space though
Old Jun 6, 2012 | 12:22 PM
NmexMAX's Avatar
dot dot dot ...
Looks like you have 2 more to go.
Old Jun 6, 2012 | 12:29 PM
This.
THIS
And this. The rear is the one that fails. They're also the ones that have bad compression and wear the fastest due to excess heat and poor air flow.
Old Jun 6, 2012 | 07:23 PM
Rods03Max619's Avatar
Good Luck Man....
Old Jun 7, 2012 | 11:01 AM
NyMax03se's Avatar
Good Luck Man....
thanks^
i took it to someone today they did a smoke test on the engine to find and leaks in the air system... When they did it alot of smoke was coming from the left side of the throttle body... it was coming out of the VIAS valve
Old Jun 7, 2012 | 11:09 AM
NmexMAX's Avatar
dot dot dot ...
thanks^
The VIAS (potential for leaking) is no where near the TB.
Old Jun 7, 2012 | 11:28 AM
NyMax03se's Avatar
ok i might be wrong of the location but im right about the part. i was on NWPengineering and was looking at the VIAS blockoff for the 3.5vq and that was the part that it smoking from..
Old Jun 7, 2012 | 11:50 AM
NmexMAX's Avatar
dot dot dot ...
ok i might be wrong of the location but im right about the part. i was on NWPengineering and was looking at the VIAS blockoff for the 3.5vq and that was the part that was smoking from..
Ahh, so, there are a lot of potential leakage areas there. Most obvious is the rear VC ... the one that is prone to cracking.
Another being the VIAS valve cover, the PCV valve, (just under that area) and of course all of the associated UIM/LIM gaskets.
Old Jun 7, 2012 | 11:52 AM
My thoughts exactly
Old Jun 7, 2012 | 12:57 PM
NyMax03se's Avatar
but yea that was the only place where smoke was coming from. now im looking for a replacement... thanks anyway guys
Old Jun 7, 2012 | 01:00 PM
NmexMAX's Avatar
dot dot dot ...
A replacement engine because of a cracked valve cover? Noo!
Old Jun 7, 2012 | 01:12 PM
NyMax03se's Avatar
now if i get the block off instead of the new valve will it trip a CEL.
Old Jun 7, 2012 | 01:26 PM
NmexMAX's Avatar
dot dot dot ...
Nope.
But I would pinpoint the leak first. And that wont cause your SES. Not taht small of a leak.
Hell, I've removed my BOP cover many many many many times without changing the gasket over the years and have yet to have any sort of leak or SES.
Old Jun 7, 2012 | 02:00 PM
NyMax03se's Avatar
NO not an engine. Just the VIAS valve or the entire upper intake manifold. the valve covers are fine even the one in the back. it's leaking from Vias where power actuator meets the variable air time valve.
Old Jun 7, 2012 | 02:01 PM
NmexMAX's Avatar
dot dot dot ...
NO not an engine either the VIAS valve or the entire upper intake manifold
Have you verified a crack or could it be coming from below, like the rear valve cover?
